Im sending notifications from a RaspberryPi with Apprise to Homeassistant.
Like: ‘apprise -vvv hassios://{host}/{access_token}’
HA is receiving the notifications on the left sidebar. Everything works.
But I wanted to receive the notifications as sensor, so I could show them on the dashboard, or making math with it.
Is it possible to generate a sensor fetching the notifications?
thanks in advance!
If you create persistent_notifications with a notification_id,
service: persistent_notification.create
title: My Title
message: My Message
notification_id: '1234'
you can make a template senor with the attributes.
This isn’t fully debugged, but hopefully it gives you a foundation to work from…
template:
- sensor:
- name: Persistent List
state: "{{ states.persistent_notification | list }}"
availability: "{{ states.persistent_notification | list != [] }}"
- trigger:
- platform: state
entity_id:
- sensor.persistent_list
not_to:
- unavailable
- unknown
variables:
message: "{{ ((states.persistent_notification | list)[-1].attributes).message }}"
title: "{{ ((states.persistent_notification | list)[-1].attributes).title }}"
- platform: state
entity_id:
- persistent_notification.invalid_config
not_to:
- unavailable
- unknown
variables:
message: "{{ trigger.to_state.attributes.message }}"
title: "{{ trigger.to_state.attributes.title }}"
- name: Persistent Notification
state: "{{ message }}"
attributes:
history: >
{% set current = this.attributes.get('history', []) %}
{% set new = [{
"title": title,
"message": message,
"time": now().strftime("%A, %-I:%M%p") }] %}
{{ (new + current)[:10] }}
BastianLi
(Bastian Li)
May 21, 2023, 4:26pm
4
hello,
Ive completed it.
Im using BirdnetPi . A acoustic bird classification on a Raspberrypi.
Every time a new bird is identified, the pi sends a persistent notification to Home Assistant via apprise .
Apprise could speak mqtt, but with the home assistant persistent notification I don’t need a mqtt broker.
Created a template sensor, I map all messages from persistent_notification containing “New BirdNET-Pi Detection”
- sensor:
- name: "notification_list"
state: >-
{{ ((states.persistent_notification | selectattr('attributes.title', 'eq', 'New BirdNET-Pi Detection') | list)[-1].attributes).title }}
attributes:
message: >-
{{ ((states.persistent_notification | selectattr('attributes.title', 'eq', 'New BirdNET-Pi Detection') | list)[-1].attributes).message }}
So I can show the newest detection on the dashboard.
Because there a more than 100 messages, a automation dismiss all notifications at 9:00 containing “New BirdNET-Pi Detection”
alias: dismis
description: ""
mode: single
- platform: time
# This trigger will fire at 9:00
at: "09:00:00"
#- alias: Repeat Dismiss action for all
repeat:
for_each: >-
{{ states.persistent_notification | selectattr('attributes.title', 'eq', 'New BirdNET-Pi Detection') | map(attribute='object_id') | list }}
sequence:
- service: persistent_notification.dismiss
notification_id: "{{ repeat.item }}"
Thank you!
Just a heads up, it looks like this is going to break in 2023.06…
poudenes
(Poudenes)
July 5, 2023, 6:07am
6
I tried this on HA 2023.6.3 and I don’t see the states are all when I check states in dev area
I am trying to implement the same functionality. Has anyone found a workaround? Those persistent_notification states are no longer available as far as I can tell.
