Hello all!
I recently upgraded to hass 0.87.1 and have been having a strange problem ever since. For whatever reason FFmpeg integration seems to have broken, and this is causing my amcrest component to error out as well. The video stream still displays snapshots just fine in lovelace, but clicking on the image to view full size will never load. In addition to that, I monitor SD card space, and motion detection with this camera and neither sensor shows up in the UI any more. There have been no camera configuration changes on the device, or in hass, and firewall rules / my routing tables are unchanged. The only thing that has changed since this broke is an upgrade to 0.87.1
This is the error I see on boot:
2019-02-20 14:31:29 ERROR (MainThread) [haffmpeg.core] FFmpeg fails [Errno 2] No such file or directory: 'ffmpeg': 'ffmpeg'
File "/srv/homeassistant/lib/python3.6/site-packages/haffmpeg/core.py", line 114, in open
stderr=stderr
File "/opt/rh/rh-python36/root/usr/lib64/python3.6/asyncio/subprocess.py", line 225, in create_subprocess_exec
stderr=stderr, **kwds)
File "/opt/rh/rh-python36/root/usr/lib64/python3.6/asyncio/base_events.py", line 1191, in subprocess_exec
bufsize, **kwargs)
File "/opt/rh/rh-python36/root/usr/lib64/python3.6/asyncio/unix_events.py", line 191, in _make_subprocess_transport
**kwargs)
File "/opt/rh/rh-python36/root/usr/lib64/python3.6/asyncio/base_subprocess.py", line 39, in __init__
stderr=stderr, bufsize=bufsize, **kwargs)
File "/opt/rh/rh-python36/root/usr/lib64/python3.6/asyncio/unix_events.py", line 697, in _start
universal_newlines=False, bufsize=bufsize, **kwargs)
File "/opt/rh/rh-python36/root/usr/lib64/python3.6/subprocess.py", line 709, in __init__
restore_signals, start_new_session)
File "/opt/rh/rh-python36/root/usr/lib64/python3.6/subprocess.py", line 1344, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: 'ffmpeg': 'ffmpeg'
2019-02-20 14:31:29 WARNING (MainThread) [haffmpeg.tools] Error starting FFmpeg.
2019-02-20 14:31:30 ERROR (MainThread) [homeassistant.components.sensor] amcrest: Error on device update!
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 248, in _async_add_entity
await entity.async_device_update(warning=False)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 349, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/opt/rh/rh-python36/root/usr/lib64/python3.6/concurrent/futures/thread.py", line 56, in run
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/sensor/amcrest.py", line 103, in update
sd_used = self._camera.storage_used
File "/srv/homeassistant/lib/python3.6/site-packages/amcrest/storage.py", line 39, in storage_used
status = [s for s in ret.split() if '.UsedBytes=' in s][0]
IndexError: list index out of range
If I try to view the full size image through the UI, I will be presented with this error:
2019-02-20 14:53:11 ERROR (MainThread) [haffmpeg.core] FFmpeg fails [Errno 2] No such file or directory: 'ffmpeg': 'ffmpeg'
stderr=stderr
bufsize, **kwargs)
**kwargs)
2019-02-20 14:53:11 WARNING (MainThread) [haffmpeg.core] FFmpeg isn't running!
2019-02-20 14:53:11 ERROR (MainThread) [aiohttp.server] Error handling request
File "/srv/homeassistant/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 418, in start
resp = await task
File "/srv/homeassistant/lib/python3.6/site-packages/aiohttp/web_app.py", line 458, in _handle
resp = await handler(request)
File "/srv/homeassistant/lib/python3.6/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/http/real_ip.py", line 34, in real_ip_middleware
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/http/ban.py", line 67, in ban_middleware
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/http/auth.py", line 99, in auth_middleware
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/http/view.py", line 118, in handle
result = await result
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/camera/__init__.py", line 407, in get
return await self.handle(request, camera)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/camera/__init__.py", line 443, in handle
return await camera.handle_async_mjpeg_stream(request)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/camera/amcrest.py", line 85, in handle_async_mjpeg_stream
self._ffmpeg.ffmpeg_stream_content_type)
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/aiohttp_client.py", line 111, in async_aiohttp_proxy_stream
data = await stream.read(buffer_size)
File "/srv/homeassistant/lib/python3.6/site-packages/haffmpeg/core.py", line 155, in read
return self._proc.stdout.read(count)
AttributeError: 'NoneType' object has no attribute 'stdout'
2019-02-20 14:53:11 ERROR (MainThread) [aiohttp.server] Unhandled exception
File "/srv/homeassistant/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 447, in start
await resp.prepare(request)
File "/srv/homeassistant/lib/python3.6/site-packages/aiohttp/web_response.py", line 353, in prepare
return await self._start(request)
File "/srv/homeassistant/lib/python3.6/site-packages/aiohttp/web_response.py", line 667, in _start
return await super()._start(request)
File "/srv/homeassistant/lib/python3.6/site-packages/aiohttp/web_response.py", line 410, in _start
await writer.write_headers(status_line, headers)
File "/srv/homeassistant/lib/python3.6/site-packages/aiohttp/http_writer.py", line 112, in write_headers
self._write(buf)
File "/srv/homeassistant/lib/python3.6/site-packages/aiohttp/http_writer.py", line 67, in _write
raise ConnectionResetError('Cannot write to closing transport')
ConnectionResetError: Cannot write to closing transport
