I’ve set up 2 ffmpeg cameras in my configuration.yaml file, which point to 2 traffic camera streams in my area. It works perfectly, however I notice after some time, resources will peg, which shouldn’t be happening (I’m running in a VM with plenty of RAM/CPU, not in Pi). When I look in the OS, I see this:
mike@ubuntu:~$ ps -ef | grep ffm
mike 126791 126706 2 12:43 ? 00:00:13 ffmpeg -i http://8.15.251.102:1935/rtplive/R4_104/playlist.m3u8 -an -c:v mjpeg -q:v 2 -f mpjpeg -
mike 126899 126706 2 12:45 ? 00:00:09 ffmpeg -i http://8.15.251.102:1935/rtplive/R4_104/playlist.m3u8 -an -c:v mjpeg -q:v 2 -f mpjpeg -
mike 126910 126706 2 12:46 ? 00:00:11 ffmpeg -i http://8.15.251.102:1935/rtplive/R4_105/playlist.m3u8 -an -c:v mjpeg -q:v 2 -f mpjpeg -
mike 126939 126706 2 12:46 ? 00:00:10 ffmpeg -i http://8.15.251.102:1935/rtplive/R4_105/playlist.m3u8 -an -c:v mjpeg -q:v 2 -f mpjpeg -
The two streams are doubled up, even though I have no browsers actively viewing it, nor do these processes ever terminate after 10 minutes, for example. Is this by design? Should I add some sort of additional parameter to ffmpeg that only captures 60 seconds of footage as a workaround?
Thanks for any info!
EDIT: Right after posting, 3 of the 4 processes died off without any intervention on my part. Perhaps I need to just be more patient…
mike 126791 126706 2 12:44 ? 00:00:22 ffmpeg -i http://8.15.251.102:1935/rtplive/R4_104/playlist.m3u8 -an -c:v mjpeg -q:v 2 -f mpjpeg -
I also suspect I had doubled up processes since I viewed both feeds from my phone and my desktop?
EDIT 2:
After all ffmpeg processes died out, I simply viewed a camera feed twice from my phone, and now I see 4 processes on same source:
mike 127153 126706 5 13:01 ? 00:00:00 ffmpeg -i http://8.15.251.102:1935/rtplive/R4_104/playlist.m3u8 -an -c:v mjpeg -q:v 2 -f mpjpeg -
mike 127157 126706 5 13:01 ? 00:00:00 ffmpeg -i http://8.15.251.102:1935/rtplive/R4_104/playlist.m3u8 -an -c:v mjpeg -q:v 2 -f mpjpeg -
mike 127158 126706 5 13:01 ? 00:00:00 ffmpeg -i http://8.15.251.102:1935/rtplive/R4_104/playlist.m3u8 -an -c:v mjpeg -q:v 2 -f mpjpeg -
mike 127162 126706 7 13:02 ? 00:00:00 ffmpeg -i http://8.15.251.102:1935/rtplive/R4_104/playlist.m3u8 -an -c:v mjpeg -q:v 2 -f mpjpeg -
So yes, I am still confused what I’m doing wrong
Here’s my YAML btw:
camera:
- platform: ffmpeg
extra_arguments: -q:v 2
input: http://8.15.251.102:1935/rtplive/R4_104/playlist.m3u8
- platform: ffmpeg
name: I-240 Walnut Grove
input: http://8.15.251.102:1935/rtplive/R4_105/playlist.m3u8
