I’m trying to get streams from my UniFi Cameras.
camera: - platform: ffmpeg name: Cam input: -rtsp_transport tcp -i rtsp://192.168.1.20:7447/58185d11e4b0b3ba83376c96_0
I’ve downloaded FFMpeg binaries and put the directory in the PATH.
Getting a bunch of errors and “Cam(Error loading Camera)” in the frontend.
17-01-04 23:33:38 rxv: Invalid XML returned for request <YAMAHA_AV cmd="GET"><Zone_4><Volume><Mute>GetParam</Mute></Volume></Zone_4></YAMAHA_AV>: b'' Traceback (most recent call last): File "C:\Users\Owner\AppData\Roaming\.homeassistant\deps\rxv\rxv.py", line 131, in _request response = ET.XML(res.content) # releases connection to the pool File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\xml\etree\ElementTree.py", line 1334, in XML return parser.close() File "<string>", line None xml.etree.ElementTree.ParseError: no element found: line 1, column 0 17-01-04 23:33:38 homeassistant.components.media_player: Error while setting up platform yamaha Traceback (most recent call last): File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\helpers\entity_component.py", line 150, in _async_setup_platform entity_platform.add_entities, discovery_info File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\futures.py", line 361, in __iter__ yield self # This tells Task to wait for completion. File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\tasks.py", line 296, in _wakeup future.result() File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\futures.py", line 274, in result raise self._exception File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\concurrent\futures\thread.py", line 55, in run result = self.fn(*self.args, **self.kwargs) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\components\media_player\yamaha.py", line 89, in setup_platform YamahaDevice(name, receiver, source_ignore, source_names)]) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\components\media_player\yamaha.py", line 108, in __init__ self.update() File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\components\media_player\yamaha.py", line 125, in update self._muted = self._receiver.mute File "C:\Users\Owner\AppData\Roaming\.homeassistant\deps\rxv\rxv.py", line 443, in mute response = self._request('GET', request_text) File "C:\Users\Owner\AppData\Roaming\.homeassistant\deps\rxv\rxv.py", line 131, in _request response = ET.XML(res.content) # releases connection to the pool File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\xml\etree\ElementTree.py", line 1334, in XML return parser.close() File "<string>", line None xml.etree.ElementTree.ParseError: no element found: line 1, column 0 17-01-04 23:34:01 haffmpeg.core: FFmpeg fails [WinError 2] The system cannot find the file specified Traceback (most recent call last): File "C:\Users\Owner\AppData\Roaming\.homeassistant\deps\haffmpeg\core.py", line 243, in open stderr=stderr File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\subprocess.py", line 212, in create_subprocess_exec stderr=stderr, **kwds) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\base_events.py", line 1079, in subprocess_exec bufsize, **kwargs) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\windows_events.py", line 373, in _make_subprocess_transport **kwargs) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\base_subprocess.py", line 40, in __init__ stderr=stderr, bufsize=bufsize, **kwargs) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\windows_events.py", line 757, in _start bufsize=bufsize, **kwargs) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\windows_utils.py", line 204, in __init__ stderr=stderr_wfd, **kwds) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\subprocess.py", line 947, in __init__ restore_signals, start_new_session) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\subprocess.py", line 1224, in _execute_child startupinfo) FileNotFoundError: [WinError 2] The system cannot find the file specified 17-01-04 23:34:01 aiohttp.server: Error handling request Traceback (most recent call last): File "C:\Users\Owner\AppData\Roaming\.homeassistant\deps\aiohttp\web_server.py", line 61, in handle_request resp = yield from self._handler(request) File "C:\Users\Owner\AppData\Roaming\.homeassistant\deps\aiohttp\web.py", line 249, in _handle resp = yield from handler(request) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\coroutines.py", line 209, in coro res = yield from res File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\coroutines.py", line 209, in coro res = yield from res File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\components\http\__init__.py", line 427, in handle result = yield from result File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\components\camera\__init__.py", line 186, in get response = yield from self.handle(request, camera) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\components\camera\__init__.py", line 204, in handle image = yield from camera.async_camera_image() File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\components\camera\ffmpeg.py", line 64, in async_camera_image extra_cmd=self._extra_arguments) File "C:\Users\Owner\AppData\Roaming\.homeassistant\deps\haffmpeg\tools.py", line 162, in get_image image, error = yield from self._proc.communicate() AttributeError: 'NoneType' object has no attribute 'communicate' 17-01-04 23:34:06 haffmpeg.core: FFmpeg fails [WinError 2] The system cannot find the file specified Traceback (most recent call last): File "C:\Users\Owner\AppData\Roaming\.homeassistant\deps\haffmpeg\core.py", line 243, in open stderr=stderr File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\subprocess.py", line 212, in create_subprocess_exec stderr=stderr, **kwds) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\base_events.py", line 1079, in subprocess_exec bufsize, **kwargs) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\windows_events.py", line 373, in _make_subprocess_transport **kwargs) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\base_subprocess.py", line 40, in __init__ stderr=stderr, bufsize=bufsize, **kwargs) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\windows_events.py", line 757, in _start bufsize=bufsize, **kwargs) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\windows_utils.py", line 204, in __init__ stderr=stderr_wfd, **kwds) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\subprocess.py", line 947, in __init__ restore_signals, start_new_session) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\subprocess.py", line 1224, in _execute_child startupinfo) FileNotFoundError: [WinError 2] The system cannot find the file specified 17-01-04 23:34:06 aiohttp.server: Error handling request Traceback (most recent call last): File "C:\Users\Owner\AppData\Roaming\.homeassistant\deps\aiohttp\web_server.py", line 61, in handle_request resp = yield from self._handler(request) File "C:\Users\Owner\AppData\Roaming\.homeassistant\deps\aiohttp\web.py", line 249, in _handle resp = yield from handler(request) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\coroutines.py", line 209, in coro res = yield from res File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\coroutines.py", line 209, in coro res = yield from res File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\components\http\__init__.py", line 427, in handle result = yield from result File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\components\camera\__init__.py", line 186, in get response = yield from self.handle(request, camera) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\components\camera\__init__.py", line 204, in handle image = yield from camera.async_camera_image() File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\components\camera\ffmpeg.py", line 64, in async_camera_image extra_cmd=self._extra_arguments) File "C:\Users\Owner\AppData\Roaming\.homeassistant\deps\haffmpeg\tools.py", line 162, in get_image image, error = yield from self._proc.communicate() AttributeError: 'NoneType' object has no attribute 'communicate' 17-01-04 23:34:11 haffmpeg.core: FFmpeg fails [WinError 2] The system cannot find the file specified Traceback (most recent call last): File "C:\Users\Owner\AppData\Roaming\.homeassistant\deps\haffmpeg\core.py", line 243, in open stderr=stderr File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\subprocess.py", line 212, in create_subprocess_exec stderr=stderr, **kwds) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\base_events.py", line 1079, in subprocess_exec bufsize, **kwargs) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\windows_events.py", line 373, in _make_subprocess_transport **kwargs) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\base_subprocess.py", line 40, in __init__ stderr=stderr, bufsize=bufsize, **kwargs) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\windows_events.py", line 757, in _start bufsize=bufsize, **kwargs) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\asyncio\windows_utils.py", line 204, in __init__ stderr=stderr_wfd, **kwds) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\subprocess.py", line 947, in __init__ restore_signals, start_new_session) File "C:\Users\Owner\AppData\Local\Programs\Python\Python35-32\lib\subprocess.py", line 1224, in _execute_child startupinfo) FileNotFoundError: [WinError 2] The system cannot find the file specified
