I have one IP camera and want to integrate it into HA as a camera FFmpeg and FFmpeg motion sensor. This results in HA that it’s using 2 streams at the same time.
Additionally I have create a small script, still perfecting, to start and stop recording from that same stream. using a switch component.
This results in the use of 3 streams if everything is up and running. Is there a way to reduce it to 1 stream, to reduce the bandwidth?
My camera is a DAHUA DH-IPC-HDBW4431R-ZS. I’m using the rstp protocol.
Any suggestions to my problem is welcome.
