I am trying to use ffmpeg_motion on an image file:
binary_sensor:
- name: ffmpeg_motion_on_file
platform: ffmpeg_mtion
input: "/media/my_snapshot_file.jpg"
Then use the developper services tab to start ffmpeg
service: ffmpeg.start
data: {}
The history shows that ffmpeg_motion tries to launch and immediatly becomes “unavailable”
No additional logs are made
I also tried specifying the ffmpeg
binary manually in the configuration.yaml file:
ffmpeg:
ffmpeg_bin: "/usr/bin/ffmpeg"
I can launch the ffmpeg utility manually using the ssh add-on without any trouble.
How could I get more logs about this so I can debug the problem?
EDIT:
I managed to get some more logs from HA but couldn’t find the bug:
2023-08-27 01:04:10.824 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474357713344] <user> from <IP_addr> (<UserAgent>): Received {'type': 'execute_script', 'sequence': [{'service': 'ffmpeg.start', 'data': {}}], 'id': 43}
2023-08-27 01:04:10.836 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event call_service[L]: domain=ffmpeg, service=start, service_data=>)
2023-08-27 01:04:10.845 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event state_changed[L]: entity_id=binary_sensor.ffmpeg_motion_camera_snapshot, old_state=<state binary_sensor.ffmpeg_motion_camera_snapshot=unavailable; device_class=motion, friendly_name=ffmpeg_motion_camera_snapshot @ 2023-08-27T01:01:45.815991+02:00>, new_state=<state binary_sensor.ffmpeg_motion_camera_snapshot=off; device_class=motion, friendly_name=ffmpeg_motion_camera_snapshot @ 2023-08-27T01:04:10.844378+02:00>>)
2023-08-27 01:04:10.847 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474357270976] <user> from <IP_addr> (<UserAgent>): Sending {"id":296,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"off","lc":1693091050.844378,"c":"01H8T1EDAW9HHXZRZGHCDQ0VCZ"}}}}}
2023-08-27 01:04:10.848 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474356993344] <user> from <IP_addr> (<UserAgent>): Sending {"id":20,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"off","lc":1693091050.844378,"c":"01H8T1EDAW9HHXZRZGHCDQ0VCZ"}}}}}
2023-08-27 01:04:10.851 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474357713344] <user> from <IP_addr> (<UserAgent>): Sending {"id":19,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"off","lc":1693091050.844378,"c":"01H8T1EDAW9HHXZRZGHCDQ0VCZ"}}}}}
2023-08-27 01:04:10.853 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474357725248] <user> from <IP_addr> (<UserAgent>): Sending {"id":21,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"off","lc":1693091050.844378,"c":"01H8T1EDAW9HHXZRZGHCDQ0VCZ"}}}}}
2023-08-27 01:04:11.002 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474357270976] <user> from <IP_addr> (<UserAgent>): Sending {"id":296,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"unavailable","lc":1693091051.001359,"c":"01H8T1EDFSZ2BJJ9Q1CCJFSVKG"}}}}}
2023-08-27 01:04:11.004 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event state_changed[L]: entity_id=binary_sensor.ffmpeg_motion_camera_snapshot, old_state=<state binary_sensor.ffmpeg_motion_camera_snapshot=off; device_class=motion, friendly_name=ffmpeg_motion_camera_snapshot @ 2023-08-27T01:04:10.844378+02:00>, new_state=<state binary_sensor.ffmpeg_motion_camera_snapshot=unavailable; device_class=motion, friendly_name=ffmpeg_motion_camera_snapshot @ 2023-08-27T01:04:11.001359+02:00>>)
2023-08-27 01:04:11.007 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474356993344] <user> from <IP_addr> (<UserAgent>): Sending {"id":20,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"unavailable","lc":1693091051.001359,"c":"01H8T1EDFSZ2BJJ9Q1CCJFSVKG"}}}}}
2023-08-27 01:04:11.008 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474357713344] <user> from <IP_addr> (<UserAgent>): Sending {"id":19,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"unavailable","lc":1693091051.001359,"c":"01H8T1EDFSZ2BJJ9Q1CCJFSVKG"}}}}}
2023-08-27 01:04:11.009 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474357725248] <user> from <IP_addr> (<UserAgent>): Sending {"id":21,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"unavailable","lc":1693091051.001359,"c":"01H8T1EDFSZ2BJJ9Q1CCJFSVKG"}}}}}
2023-08-27 01:04:11.207 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474356993344] <user> from <IP_addr> (<UserAgent>): Sending {"id":43,"type":"event","event":{"events":[{"when":1693091050.844378,"state":"off","entity_id":"binary_sensor.ffmpeg_motion_camera_snapshot"},{"when":1693091051.001359,"state":"unavailable","entity_id":"binary_sensor.ffmpeg_motion_camera_snapshot"}]}}
2023-08-27 01:04:26.614 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474357713344] <user> from <IP_addr> (<UserAgent>): Received {'type': 'execute_script', 'sequence': [{'service': 'ffmpeg.start', 'data': {}}], 'id': 44}
2023-08-27 01:04:26.622 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event call_service[L]: domain=ffmpeg, service=start, service_data=>)
2023-08-27 01:04:26.630 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event state_changed[L]: entity_id=binary_sensor.ffmpeg_motion_camera_snapshot, old_state=<state binary_sensor.ffmpeg_motion_camera_snapshot=unavailable; device_class=motion, friendly_name=ffmpeg_motion_camera_snapshot @ 2023-08-27T01:04:11.001359+02:00>, new_state=<state binary_sensor.ffmpeg_motion_camera_snapshot=off; device_class=motion, friendly_name=ffmpeg_motion_camera_snapshot @ 2023-08-27T01:04:26.629960+02:00>>)
2023-08-27 01:04:26.631 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474357270976] <user> from <IP_addr> (<UserAgent>): Sending {"id":296,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"off","lc":1693091066.62996,"c":"01H8T1EWR58DV43Q593E0BWFQ6"}}}}}
2023-08-27 01:04:26.633 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474356993344] <user> from <IP_addr> (<UserAgent>): Sending {"id":20,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"off","lc":1693091066.62996,"c":"01H8T1EWR58DV43Q593E0BWFQ6"}}}}}
2023-08-27 01:04:26.635 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474357713344] <user> from <IP_addr> (<UserAgent>): Sending {"id":19,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"off","lc":1693091066.62996,"c":"01H8T1EWR58DV43Q593E0BWFQ6"}}}}}
2023-08-27 01:04:26.637 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474357725248] <user> from <IP_addr> (<UserAgent>): Sending {"id":21,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"off","lc":1693091066.62996,"c":"01H8T1EWR58DV43Q593E0BWFQ6"}}}}}
2023-08-27 01:04:26.719 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474357270976] <user> from <IP_addr> (<UserAgent>): Sending {"id":296,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"unavailable","lc":1693091066.719074,"c":"01H8T1EWTZC9YRAD4P0VR3FKAQ"}}}}}
2023-08-27 01:04:26.720 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event state_changed[L]: entity_id=binary_sensor.ffmpeg_motion_camera_snapshot, old_state=<state binary_sensor.ffmpeg_motion_camera_snapshot=off; device_class=motion, friendly_name=ffmpeg_motion_camera_snapshot @ 2023-08-27T01:04:26.629960+02:00>, new_state=<state binary_sensor.ffmpeg_motion_camera_snapshot=unavailable; device_class=motion, friendly_name=ffmpeg_motion_camera_snapshot @ 2023-08-27T01:04:26.719074+02:00>>)
2023-08-27 01:04:26.722 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474356993344] <user> from <IP_addr> (<UserAgent>): Sending {"id":20,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"unavailable","lc":1693091066.719074,"c":"01H8T1EWTZC9YRAD4P0VR3FKAQ"}}}}}
2023-08-27 01:04:26.723 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474357713344] <user> from <IP_addr> (<UserAgent>): Sending {"id":19,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"unavailable","lc":1693091066.719074,"c":"01H8T1EWTZC9YRAD4P0VR3FKAQ"}}}}}
2023-08-27 01:04:26.724 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474357725248] <user> from <IP_addr> (<UserAgent>): Sending {"id":21,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"unavailable","lc":1693091066.719074,"c":"01H8T1EWTZC9YRAD4P0VR3FKAQ"}}}}}
2023-08-27 01:04:26.990 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474356993344] <user> from <IP_addr> (<UserAgent>): Sending {"id":43,"type":"event","event":{"events":[{"when":1693091066.62996,"state":"off","entity_id":"binary_sensor.ffmpeg_motion_camera_snapshot"},{"when":1693091066.719074,"state":"unavailable","entity_id":"binary_sensor.ffmpeg_motion_camera_snapshot"}]}}
2023-08-27 01:04:53.387 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474357713344] <user> from <IP_addr> (<UserAgent>): Received {'type': 'execute_script', 'sequence': [{'service': 'ffmpeg.start', 'data': {}}], 'id': 45}
2023-08-27 01:04:53.396 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event call_service[L]: domain=ffmpeg, service=start, service_data=>)
2023-08-27 01:04:53.403 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event state_changed[L]: entity_id=binary_sensor.ffmpeg_motion_camera_snapshot, old_state=<state binary_sensor.ffmpeg_motion_camera_snapshot=unavailable; device_class=motion, friendly_name=ffmpeg_motion_camera_snapshot @ 2023-08-27T01:04:26.719074+02:00>, new_state=<state binary_sensor.ffmpeg_motion_camera_snapshot=off; device_class=motion, friendly_name=ffmpeg_motion_camera_snapshot @ 2023-08-27T01:04:53.403692+02:00>>)
2023-08-27 01:04:53.405 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474357270976] <user> from <IP_addr> (<UserAgent>): Sending {"id":296,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"off","lc":1693091093.403692,"c":"01H8T1FPWVRP3Z8ZB2E9GDVH2B"}}}}}
2023-08-27 01:04:53.408 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474356993344] <user> from <IP_addr> (<UserAgent>): Sending {"id":20,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"off","lc":1693091093.403692,"c":"01H8T1FPWVRP3Z8ZB2E9GDVH2B"}}}}}
2023-08-27 01:04:53.410 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474357713344] <user> from <IP_addr> (<UserAgent>): Sending {"id":19,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"off","lc":1693091093.403692,"c":"01H8T1FPWVRP3Z8ZB2E9GDVH2B"}}}}}
2023-08-27 01:04:53.412 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474357725248] <user> from <IP_addr> (<UserAgent>): Sending {"id":21,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"off","lc":1693091093.403692,"c":"01H8T1FPWVRP3Z8ZB2E9GDVH2B"}}}}}
2023-08-27 01:04:53.516 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474357270976] <user> from <IP_addr> (<UserAgent>): Sending {"id":296,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"unavailable","lc":1693091093.516572,"c":"01H8T1FQ0C7MJTVCT0SKVS21XN"}}}}}
2023-08-27 01:04:53.519 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: EventTask(event=<Event state_changed[L]: entity_id=binary_sensor.ffmpeg_motion_camera_snapshot, old_state=<state binary_sensor.ffmpeg_motion_camera_snapshot=off; device_class=motion, friendly_name=ffmpeg_motion_camera_snapshot @ 2023-08-27T01:04:53.403692+02:00>, new_state=<state binary_sensor.ffmpeg_motion_camera_snapshot=unavailable; device_class=motion, friendly_name=ffmpeg_motion_camera_snapshot @ 2023-08-27T01:04:53.516572+02:00>>)
2023-08-27 01:04:53.521 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474356993344] <user> from <IP_addr> (<UserAgent>): Sending {"id":20,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"unavailable","lc":1693091093.516572,"c":"01H8T1FQ0C7MJTVCT0SKVS21XN"}}}}}
2023-08-27 01:04:53.523 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474357713344] <user> from <IP_addr> (<UserAgent>): Sending {"id":19,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"unavailable","lc":1693091093.516572,"c":"01H8T1FQ0C7MJTVCT0SKVS21XN"}}}}}
2023-08-27 01:04:53.524 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474357725248] <user> from <IP_addr> (<UserAgent>): Sending {"id":21,"type":"event","event":{"c":{"binary_sensor.ffmpeg_motion_camera_snapshot":{"+":{"s":"unavailable","lc":1693091093.516572,"c":"01H8T1FQ0C7MJTVCT0SKVS21XN"}}}}}
2023-08-27 01:04:53.775 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140474356993344] <user> from <IP_addr> (<UserAgent>): Sending {"id":43,"type":"event","event":{"events":[{"when":1693091093.403692,"state":"off","entity_id":"binary_sensor.ffmpeg_motion_camera_snapshot"},{"when":1693091093.516572,"state":"unavailable","entity_id":"binary_sensor.ffmpeg_motion_camera_snapshot"}]}}
