FGS211 / FGS221 JS Zwave not return status
since the last update of JS Zwave my FGS211 / FGS221 not return the status of one switch.
He works but I don’t know if is switch on or off.
Any idea ?
Thx
I have the same problem
I have open a issue on github :
Same here with FGS-222. But, I think, the fix is on the way:
Good news: with the last zwave-js update 0.1.18
FGS-222 (at least, maybe also other models) can update their status finally!
For me also :smiley:
I use FGS212 and had the same problem described here with zwave-js before v0.1.18. With v0.1.18 it was working but since I update zwave-js to v0.1.3x and now v0.1.40 I don’t get the status :frowning:
do someone have the same problem?
@Ascari @Aleksei_Piatkin: are your FGS-222 / FGS211 / FGS221 working with newest version of zwave-js?
would be great to get some tips for my FGS-212. thanks j
Now working yes
any idea what could be the problem with my FGS212?
Hmm strange, with version 0.1.40 all my FGS-222 still update the status.
Strange I’m on 0.1.40 and work perfectly try to reinterview the node maybe ?
I already tried a couple of time by reinterviewing. reinterview was successful but without any diffrence of reporting status, still not working :frowning:
here to zwave-js log if I press the switch on the wall (without status update in HA):
2021-09-25T09:13:36.888Z SERIAL « 0x01090004000603250300d1                                            (11 bytes)
2021-09-25T09:13:36.890Z CNTRLR   [Node 006] [~] [Binary Switch] currentValue: false => false       [Endpoint 0]
2021-09-25T09:13:36.890Z SERIAL » [ACK]        (0x06)
2021-09-25T09:13:36.891Z DRIVER « [Node 006] [REQ] [ApplicationCommand]
                                  └─[BinarySwitchCCReport]
                                      current value: false
2021-09-25T09:16:39.687Z SERIAL « 0x010900040006032503ff2e                                            (11 bytes)
2021-09-25T09:16:39.689Z CNTRLR   [Node 006] [~] [Binary Switch] currentValue: false => true        [Endpoint 0]
2021-09-25T09:16:39.691Z SERIAL » [ACK]        (0x06)
2021-09-25T09:16:39.692Z DRIVER « [Node 006] [REQ] [ApplicationCommand]
                                      current value: true
here the log if I switch it by home assistant (here I get the status update in HA):
2021-09-25T09:24:17.243Z DRIVER » [Node 006] [REQ] [SendData]
                                  │ transmit options: 0x25
                                  │ callback id:      66
                                  └─[MultiChannelCCCommandEncapsulation]
                                    │ source:      0
                                    │ destination: 1
                                    └─[BinarySwitchCCSet]
                                        target value: true
2021-09-25T09:24:17.284Z CNTRLR   [Node 006] [~] [Binary Switch] currentValue: false => true        [Endpoint 1]
2021-09-25T09:24:18.302Z DRIVER » [Node 006] [REQ] [SendData]
                                  │ callback id:      67
                                    │ source:      0
                                    │ destination: 1
                                    └─[BinarySwitchCCGet]
2021-09-25T09:24:18.344Z CNTRLR   [Node 006] [~] [Binary Switch] currentValue: true => true         [Endpoint 1]
2021-09-25T09:24:18.349Z DRIVER « [Node 006] [REQ] [ApplicationCommand]
                                    │ source:      1
                                    │ destination: 0
                                        current value: true
the main difference is the endpoint (by switch Endpoint 0, by HA Endpoint 1). can I change this in the settings of the node? which one would it be (can’t see something similiar)?
here some device infos:
FGS212 von Fibargroup
Firmware: 2.2
Z-Wave Info
Knoten-ID: 6
Node Status: Lebendig
Node Bereit: Ja
and btw: with HA service: zwave_js.refresh_value of my entity_id: switch.relay_switch_1x2_5kw I get the actual status…
any ideas? I’m very thankful for your help!
I upgraded Z-Wave JS to 0.1.44 but still the same problems… any idea?
Same issue again with FGS211 :frowning:
Same issue with the Fibaro FGD-212…commands are sent directly, but the interface isn’t updated for like 10 seconds…switching it manually via the wall switch doesn’t update the interface anymore.
I open a issue in github :
