I have an otherwise perfectly working (except power reporting ) fibaro 3 kw switch that appears 3 times in ha.
Is it safe to delete 2 instances from the XML file ?
make a backup of the original file and try it. if it doesn’t work, restore the backup.
also rename your original entity_registry file and restart. it will create a new one based on the updated info.
