Hi all
Config: HAOS, core 2022.6.0, running on Intel NUC, Z-Wave JS to MQTT 0.42.0, Aeotec Z-stick gen 5
Issue: I have several Fibaro Dimmer 2 (FGD212) z-wave dimmers, and none of them report status changes to the entity in Home Assistant when the switch is used manually. The status (and the connected light) both work fine when turned on/off in Home Assistant.
Bizarrely, in the z-wave log, the state change is reported flawlessly when using the switch manually.
Also bizarrely, I use the second input (S2) on one of the FGD212s to trigger a separate z-wave device via associations, and this status change is updated in the frontend (though I presume from the other device?)
I can’t see any issues with the node groups/associations (lifeline is there). Anyone else encountered this? Any suggestions on how to fix it? I’m on the verge of writing an automation to manually switch the light entity on/off based on the z-wave event of it actually being turned on/off from the switch, just so the frontend updates, which seems ridiculous
