On most of z-wave devices there is an option to attach a second button to control other devices. This is exactly what i wnat to accomplish in several cases - controliing for example Sonoff Relays. So how to find this second input? Today i connected the Fibaro dimmer 2 and it has like 12 entities. Which one responds to second input i can use in automatin rules?
Why you dont test this out? I think its not a sensor, so it must be a ālightā I have the same Dimmer but Iām only using the the S1 input on the Dimmer. So I think S2 is light.fibaro_system_fgd212_dimmer_2_level_2_0_2 because it have no function for me. Try this out.
Maybe you have to change some settings in the Openzwave control panel.
All you have to do is enable the scene mode for the dimmer 2 and then create an automation which picks up on the particular scene ID depending on how many times either button is pressed (check the manual).
Btw Donāt need to use ozwcp as you can send parameter changes via HA:
Well this is pretty hard for a noob in z-wave. I have checked the parameter 28
Reading through the manual - it seems that we send parameter 1 to enable and than we will get that all fibaro dimmers 2 on s2 will have a scene id of 26 for a single push? So if i have 2 fibaro dimmers both will control scene id 26?
Thank you for the script. So it looks like i can catch the event from a single dimmer? So it wonāt be like pressing a button on any of the five (for example) will toggle the light?
Sorry for that. Lost it during the copy/paste.
Well somehow the problem was in homeassistant.turn_off
Changing it to light.turn_off almost worked. Switched off all the lights EXCEPT for the dimmer3 - the one which triggered the scene and automation rule.
After changing group.all_lights to group.lights-where i added everything by hand - works perfectly. Strange behaviour.
See the reply i gave. You can use zwave.scene_activated and read the code of the button switch. 18,22,24 e.t.c They are all laid out in fibaro dimmer 2 manual
I canāt see the scene_id in the logs, have changed multiple settings on the dimmer 2 but i canāt get it to work.
Using the s1 for a lamp and i want to use the s2 for a different lamp somewhere in the house connected to HA.
Got it wired with a āpulseā button, not the old on/off switch.
Parameters:
20: Mono-stable input (button)
26: 3-way switch function for s2 enabled
28: scene activated
32: on/off mode enabled (dimming is not possible)
Only got this in the log:
2020-11-09 11:29:23.447 Detail, Node003, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x03, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x00, 0xe0
2020-11-09 11:29:23.447 Info, Node003, Received SensorMultiLevel report from node 3, instance 1, Power: value=0.0W
2020-11-09 11:29:23.447 Detail, Node003, Refreshed Value: old value=0.2, new value=0.0, type=decimal
2020-11-09 11:29:23.447 Detail, Node003, Changes to this value are not verified
2020-11-09 11:29:23.447 Detail, Node003, Notification: ValueChanged
