Fibaro Dimmer 2 - remove the basic functionality
Using fibaro dimmers 2. So currently they control the load directly.
Now decided that i don’t want to control the load directly but instead call out scenes.
I have already set up 2nd buton to call out scenes. But the first one still controlls the load.
So i wonder if it is possible for fibaro dimmer 2 to use all the inputs (s1 and s2) to call out scenes and let home-assistant do the rest? So the first button will also just pass the scenes called and will not turn on the load attached.
Did you ever figure this out?
Interested in this as well!
I’ve tried but I haven’t managed to get the dimmer 2 to use as a scene controller without a load. If you want that sort of functionality you should get the Fibaro Single Switch 2
