Fibaro Dimmer 2 unavailable after power outage
Hi everyone! I have HA running on an RPi with an Aeotec Z-Wave stick. Electrician has been over this morning and turned off power to the house for a bit, and after turning it back on none of my Fibaro Dimmer 2 devices have reconnected to HA. They just show up as unavaliable. Any way for me to reconnect these devices without deleting them and re-adding?
Hi. The power to my house was turned off a few weeks ago but my Dimmer 2 just carried on working when the power was turned back on, so your issue is not normal.
Some suggestions: Reboot your HA host. Wait. (Maybe they will come back by themselves.) Consult the manual. Maybe do a range check on one of them to see what’s going on. Is there anything in the Z-Wave logs? Maybe you can just wake them up by toggling the switches although I assume you have tried that.
Good luck!
Thank you! I ended up checking the logs and turns out my aeotec stick had some trouble. So I put the stick on a usb extension cable and restated the host, and we are back in action!
