I need some help adding a Fibaro Door Sensor 2 to Homeassistant. I have added the sensor to Zwave (Zwave2MQTT)
Only the sensor shows up in Home Assistant as “Unknown”.
This is the OZW config:
OZW Debug:
OPZ Values unknown:
HA Entity:
value_id: 28-113-1-6
node_id: 28
class_id: 113
type: list
genre: user
instance: 1
index: 6
label: Unknown
units: ''
help: ''
read_only: true
write_only: false
min: 0
max: 0
is_polled: false
values:
- Unknown
- Unknown
- Unknown
value: Unknown
lastUpdate: 1608472187026
friendly_name: nodeID_28_alarm_access_control
icon: 'mdi:alarm-light'
I think the problem is in OZW but how can I fix it?
Thanks in advance
