Recently I purchased Fibaro door sensor FGK10x. I wanted to use if for checking the status of the door as well as for temperature measurement. I’ve installed the temperature sensor and configured the device. It showed up nicely in HA.
All was good until a reboot for HA after the upgrade to 0.52.1 (most likely not related to any release but just to the fact of the reboot).
Now, I only have one binary sensor instead of 6 or 7 I had yesterday. I cannot/don’t know how forcing refresh remotely from HA. Only way to wake it up is to press the button in the back … so, take it off the wall, press the button, install it on the wall again. But doing it every time I reboot HA is a bit of an overkill.
Do you have any other suggestions how can I ensure that the reboot of my HA will not result in cutting the number of available sensors from this device?
thanks,
Mike
