Good afternoon,
I am using several Fibaro Z-Wave door/window sensors with Home Assistant and one behaves differently than the others:
- Node009 behaves as expected: Opening the window, Node009 sends value 22 (open) and when closing it some 15 seconds later, Node009 sends value 23 (closed). Log output included below.
- Node010’s behaviour makes no sense: When opening the garage door, Node010 sends value 23 (closed) and within 2 milliseconds value 22 (open). Closing it, Node 010 sends value 22 (open) and within 3 milliseconds value 22 (open). Log output included below.
Any idea what can cause this?
Auke
Relevant system specs: Raspberry Pi 4, Aeotec Z-Stick Gen5 (ZW090-C), Fibaro System FGDW002 Door Opening Sensor 2+, Home Assistant 0.103.3
Log output device Node009 when opening and then closing the window:
2019-12-23 15:34:30.797 Detail, Node009, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x09, 0x02, 0x98, 0x40, 0x20
2019-12-23 15:34:30.797 Info, Node009, Received SecurityCmd_NonceGet from node 9
2019-12-23 15:34:30.798 Info, Node009, Sending (Send) message (Callback ID=0x01, Expected Reply=0x00) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x09, 0x0a, 0x98, 0x80, 0x94, 0x97, 0xaa, 0x49, 0xc6, 0x49, 0x54, 0x30, 0x05, 0x01, 0xe9:
2019-12-23 15:34:31.086 Detail, Node009, Received: 0x01, 0x23, 0x00, 0x04, 0x00, 0x09, 0x1d, 0x98, 0x81, 0x4d, 0x7c, 0x3b, 0xfa, 0x3e, 0x64, 0xe0, 0x24, 0xe1, 0x30, 0xd1, 0xa0, 0xe4, 0x83, 0xe5, 0x85, 0xfe, 0x48, 0x94, 0x91, 0x7f, 0x5f, 0x90, 0xab, 0x25, 0x6c, 0xe3, 0x1e
2019-12-23 15:34:31.086 Detail, Node009, Decrypted Packet: 0x00, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x06, 0x16, 0x00
2019-12-23 15:34:31.086 Info, Node009, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Access Control event:22, status=255
2019-12-23 15:34:31.086 Detail, Node009, Initial read of value
2019-12-23 15:34:31.087 Detail, Node009, Initial read of value
2019-12-23 15:34:31.087 Detail, Node009, Notification: ValueChanged
2019-12-23 15:34:31.091 Detail, Node009, Notification: ValueChanged
2019-12-23 15:34:31.095 Detail, Node009, Notification: ValueChanged
2019-12-23 15:34:31.099 Detail, Node009, Notification: ValueChanged
2019-12-23 15:34:46.194 Detail, Node009, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x09, 0x02, 0x98, 0x40, 0x20
2019-12-23 15:34:46.194 Info, Node009, Received SecurityCmd_NonceGet from node 9
2019-12-23 15:34:46.195 Info, Node009, Sending (Send) message (Callback ID=0x01, Expected Reply=0x00) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x09, 0x0a, 0x98, 0x80, 0xfc, 0x00, 0xd3, 0x54, 0x30, 0x6f, 0xf5, 0xeb, 0x05, 0x01, 0xd8:
2019-12-23 15:34:46.409 Detail, Node009, Received: 0x01, 0x23, 0x00, 0x04, 0x00, 0x09, 0x1d, 0x98, 0x81, 0xe6, 0x53, 0x31, 0xb2, 0xdb, 0x26, 0x25, 0xe2, 0x0e, 0xa9, 0x34, 0x8c, 0x1f, 0x30, 0xdb, 0x96, 0xe3, 0x9c, 0xfc, 0xde, 0x82, 0x15, 0xef, 0x3c, 0x64, 0x7a, 0xf3, 0x50
2019-12-23 15:34:46.409 Detail, Node009, Decrypted Packet: 0x00, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x06, 0x17, 0x00
2019-12-23 15:34:46.409 Info, Node009, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Access Control event:23, status=255
2019-12-23 15:34:46.409 Detail, Node009, Refreshed Value: old value=0, new value=0, type=byte
2019-12-23 15:34:46.409 Detail, Node009, Changes to this value are not verified
2019-12-23 15:34:46.410 Detail, Node009, Refreshed Value: old value=0, new value=0, type=byte
2019-12-23 15:34:46.410 Detail, Node009, Changes to this value are not verified
2019-12-23 15:34:46.410 Detail, Node009, Refreshed Value: old value=22, new value=23, type=byte
2019-12-23 15:34:46.410 Detail, Node009, Notification: ValueChanged
2019-12-23 15:34:46.419 Detail, Node009, Notification: ValueChanged
2019-12-23 15:34:46.428 Detail, Node009, Notification: ValueChanged
2019-12-23 15:34:46.438 Detail, Node009, Notification: ValueChanged
Log output device Node009 when opening the garage door:
2019-12-23 16:49:05.777 Detail, Node010, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x0a, 0x02, 0x98, 0x40, 0x23
2019-12-23 16:49:05.778 Info, Node010, Received SecurityCmd_NonceGet from node 10
2019-12-23 16:49:05.779 Info, Node010, Sending (Send) message (Callback ID=0x01, Expected Reply=0x00) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x0a, 0x0a, 0x98, 0x80, 0x7a, 0x2b, 0x9c, 0x86, 0x9e, 0x98, 0x3b, 0xd4, 0x05, 0x01, 0x43:
2019-12-23 16:49:05.969 Detail, Node010, Received: 0x01, 0x23, 0x00, 0x04, 0x00, 0x0a, 0x1d, 0x98, 0x81, 0xc7, 0x65, 0x00, 0xd4, 0x16, 0xf7, 0x29, 0x48, 0x41, 0x09, 0xf7, 0x0c, 0x6b, 0x10, 0xd7, 0xa4, 0x6b, 0xd9, 0x7a, 0x1b, 0xc5, 0x21, 0x5d, 0x35, 0x6c, 0x1c, 0x7c, 0xc8
2019-12-23 16:49:05.969 Detail, Node010, Decrypted Packet: 0x00, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x06, 0x17, 0x00
2019-12-23 16:49:05.970 Info, Node010, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Access Control event:23, status=255
2019-12-23 16:49:05.970 Detail, Node010, Refreshed Value: old value=0, new value=0, type=byte
2019-12-23 16:49:05.970 Detail, Node010, Changes to this value are not verified
2019-12-23 16:49:05.971 Detail, Node010, Changes to this value are not verified
2019-12-23 16:49:05.971 Detail, Node010, Refreshed Value: old value=22, new value=23, type=byte
2019-12-23 16:49:05.971 Detail, Node010, Notification: ValueChanged
2019-12-23 16:49:05.981 Detail, Node010, Notification: ValueChanged
2019-12-23 16:49:05.990 Detail, Node010, Notification: ValueChanged
2019-12-23 16:49:06.003 Detail, Node010, Notification: ValueChanged
2019-12-23 16:49:06.015 Detail, Node010, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x0a, 0x02, 0x98, 0x40, 0x23
2019-12-23 16:49:06.016 Info, Node010, Received SecurityCmd_NonceGet from node 10
2019-12-23 16:49:06.017 Info, Node010, Sending (Send) message (Callback ID=0x01, Expected Reply=0x00) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x0a, 0x0a, 0x98, 0x80, 0x12, 0x19, 0xec, 0x2b, 0x7b, 0x39, 0xd3, 0x4a, 0x05, 0x01, 0xf6:
2019-12-23 16:49:06.229 Detail, Node010, Received: 0x01, 0x23, 0x00, 0x04, 0x00, 0x0a, 0x1d, 0x98, 0x81, 0x78, 0xde, 0xcd, 0xdf, 0xc5, 0x69, 0x6a, 0xd7, 0x76, 0xd2, 0x56, 0x3f, 0x76, 0xe8, 0xf8, 0x3e, 0xe8, 0xc2, 0x12, 0x84, 0x4b, 0xbc, 0x3c, 0xaf, 0x90, 0x13, 0x53, 0xee
2019-12-23 16:49:06.229 Detail, Node010, Decrypted Packet: 0x00, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x06, 0x16, 0x00
2019-12-23 16:49:06.230 Info, Node010, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Access Control event:22, status=255
2019-12-23 16:49:06.230 Detail, Node010, Refreshed Value: old value=0, new value=0, type=byte
2019-12-23 16:49:06.230 Detail, Node010, Changes to this value are not verified
2019-12-23 16:49:06.231 Detail, Node010, Refreshed Value: old value=0, new value=0, type=byte
2019-12-23 16:49:06.231 Detail, Node010, Changes to this value are not verified
2019-12-23 16:49:06.232 Detail, Node010, Changes to this value are not verified
2019-12-23 16:49:06.232 Detail, Node010, Refreshed Value: old value=23, new value=22, type=byte
2019-12-23 16:49:06.232 Detail, Node010, Notification: ValueChanged
2019-12-23 16:49:06.242 Detail, Node010, Notification: ValueChanged
2019-12-23 16:49:06.247 Detail, Node010, Notification: ValueChanged
2019-12-23 16:49:06.252 Detail, Node010, Notification: ValueChanged
Log output device Node009 when closing the garage door:
2019-12-23 16:50:09.667 Detail, Node010, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x0a, 0x02, 0x98, 0x40, 0x23
2019-12-23 16:50:09.667 Info, Node010, Received SecurityCmd_NonceGet from node 10
2019-12-23 16:50:09.669 Info, Node010, Sending (Send) message (Callback ID=0x01, Expected Reply=0x00) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x0a, 0x0a, 0x98, 0x80, 0x5c, 0xe0, 0x58, 0xd0, 0xa8, 0x09, 0x41, 0xc7, 0x05, 0x01, 0xf2:
2019-12-23 16:50:09.857 Detail, Node010, Received: 0x01, 0x23, 0x00, 0x04, 0x00, 0x0a, 0x1d, 0x98, 0x81, 0x39, 0x56, 0x7b, 0x78, 0x2f, 0x7e, 0x75, 0xf5, 0x99, 0xa9, 0x94, 0x86, 0xd2, 0xa9, 0x12, 0x26, 0xb8, 0x51, 0x5c, 0x89, 0x0f, 0x2a, 0x34, 0x91, 0xd2, 0xaa, 0xf3, 0x31
2019-12-23 16:50:09.858 Detail, Node010, Decrypted Packet: 0x00, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x06, 0x16, 0x00
2019-12-23 16:50:09.858 Info, Node010, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Access Control event:22, status=255
2019-12-23 16:50:09.858 Detail, Node010, Refreshed Value: old value=0, new value=0, type=byte
2019-12-23 16:50:09.859 Detail, Node010, Changes to this value are not verified
2019-12-23 16:50:09.859 Detail, Node010, Refreshed Value: old value=0, new value=0, type=byte
2019-12-23 16:50:09.860 Detail, Node010, Refreshed Value: old value=22, new value=22, type=byte
2019-12-23 16:50:09.860 Detail, Node010, Changes to this value are not verified
2019-12-23 16:50:09.860 Detail, Node010, Notification: ValueChanged
2019-12-23 16:50:09.870 Detail, Node010, Notification: ValueChanged
2019-12-23 16:50:09.879 Detail, Node010, Notification: ValueChanged
2019-12-23 16:50:09.889 Detail, Node010, Notification: ValueChanged
2019-12-23 16:50:09.900 Detail, Node010, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x0a, 0x02, 0x98, 0x40, 0x23
2019-12-23 16:50:09.901 Info, Node010, Received SecurityCmd_NonceGet from node 10
2019-12-23 16:50:09.903 Info, Node010, Sending (Send) message (Callback ID=0x01, Expected Reply=0x00) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x0a, 0x0a, 0x98, 0x80, 0xa0, 0xd6, 0x4e, 0x38, 0x32, 0x9c, 0x1c, 0xac, 0x05, 0x01, 0xff:
2019-12-23 16:50:10.107 Detail, Node010, Received: 0x01, 0x23, 0x00, 0x04, 0x00, 0x0a, 0x1d, 0x98, 0x81, 0x85, 0x37, 0x99, 0x31, 0x27, 0x14, 0x6e, 0xa4, 0x76, 0x3d, 0xf6, 0x36, 0x82, 0x94, 0xd2, 0xd8, 0x1b, 0x24, 0xa0, 0xba, 0x87, 0x43, 0x1b, 0x85, 0xc2, 0xdb, 0x41, 0x85
2019-12-23 16:50:10.108 Detail, Node010, Decrypted Packet: 0x00, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x06, 0x16, 0x00
2019-12-23 16:50:10.108 Info, Node010, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Access Control event:22, status=255
2019-12-23 16:50:10.109 Detail, Node010, Refreshed Value: old value=0, new value=0, type=byte
2019-12-23 16:50:10.109 Detail, Node010, Changes to this value are not verified
2019-12-23 16:50:10.110 Detail, Node010, Changes to this value are not verified
2019-12-23 16:50:10.110 Detail, Node010, Refreshed Value: old value=22, new value=22, type=byte
2019-12-23 16:50:10.110 Detail, Node010, Notification: ValueChanged
2019-12-23 16:50:10.120 Detail, Node010, Notification: ValueChanged
2019-12-23 16:50:10.130 Detail, Node010, Notification: ValueChanged
2019-12-23 16:50:10.139 Detail, Node010, Notification: ValueChanged
