FIBARO Double Switch 2 \ TKB Home
Hi!
I have a problem with adding FIBARO Double Switch 2 and second button TKB Home switch on to the network with HASS.
In my setup I have some TKB Home switches, and main switch buttons on those I was able to add into HASS without any issues.
  1. Fibaro:
    In the manual it says that I have to switch the S1 3 times to add it to the network. I was able to find and add one of the switches into HASS after I brought in close proximity with that switch. However it added 3 times.
Another switch - I was unable to add it, however I did the same procedure.
Questions:
1.1 Why can’t I add it, what cause can be?
1.2 How do I remove one duplicate switch? Or is it the way it was setup? In Hass they show up as:
switch.fibaro_system_unknown_type0202_id4002_switch_7_0 off node_id: 7
friendly_name: FIBARO System Unknown: type=0202, id=4002 Switch
switch.fibaro_system_unknown_type0202_id4002_switch_7_0_2 off node_id: 7
switch.fibaro_system_unknown_type0202_id4002_switch_7_0_3 off node_id: 7
  1. TKB Home
    2.1 How do I add second button on this switch? It is virtual button, and I read somewhere that it can control other devices through group assosiation or something, how do I do that with HASS?
I know these issues are probably not that hard, I just need to tinker with them more, but community help helps to do things faster :smiley:
Thanks!
