FIBARO Double Switch verry slow
Hi there, I have a FIBARO Double Switch FSG223 integrated on my HAOS on synology nas and Z‐Stick Gen5 USB Controller. Running zwave_js. It always worked fine in response (at most 1 second and lights turned on/off with automation). Now sudenly it has become verry slow. It takes between 5 and 20 seconds to respond.
What changed:
  1. some updates on HA core and zwave_js.
  2. And, maybe important, a other fibaro device was not working as aspected. After a power cut the fibaro relay was not working until i manualy switched the relay on/off with the buton on de module. After that it was working again. I replaced the ralay. I red somewhere this could cause a problem if the device is not properly removed from zwave controller. I switched of the device in HA but no improvements (even after reboot HA). Do i have to reinstal de relay and remove it proporly?
Are there other things to try. My partner is getting crazy from lightswitches not working. Pushing twice or more. And lights eventualy going on and also off again. :slight_smile:
