Hello again, everyone!
I’m trying to setup Fibaro Dual Switch, but experiencing some problems with it.
First was that one dual switch had about 10 instances in HASS (IDs 6_0, 6_0_1. 6_0_n, 6_0_10), but that issual resolved after I removed and added it again. I think I also held the button on the switch to reset it.
But now I have another issue. Before the switch was working as expected. I’m using toggle switch, and turning it on and off was natural. Switch it once to the opposite direction (DOWN to UP or UP to DOWN), and it switched the light. Not the best approach to use toggle switch with a wall plug, as often it resulted in inverted switch position, but that’s expected.
But now it seems that after reset it changed to the “button” mode. So to switch the light, I need to press the switch into DOWN position, and then UP again.
I checked the manual, and it says there that I can set zwave parameter 14 on the plug to change it’s behaviour (toggle\button modes). I tried changing it from hass, got no errors in hass and zwave logs, but nothing changed. I tried to print parameter 14, and then other parameters from 0 to 20, and they are all returned as none.
Is this something to do with OpenZWave being incompatible with Fibaro switches? Something that was mentioned in this thread? Issue with Fibaro FGS223 Dual Switch
Or is it some other issue?
If anyone knows anything about this, would be a great help!
Thanks.
my sensor has a button I have to press 3 times.
yep mine is a battery operated sensor.
Just to mention it again
I mean, it works just the same, gives same identification, data, etc. And still no config parameters available neither in ZWave CP in HASS, nor in OZWCP. And I did restart hass after adding it.
