I have installed hassbian on my Rasberry. To control my Fibaro switches (two FDG212 dimmer, one relay switch) I use the Razberry zwave controller.
I am able to control all my switches/dimmers via the web interface of the Razberry.
However when I try to control them via Home Assistant I am not able to. Only the relay switch responds.
I have set HA to discovery and for the dimmers I only get the following light components:
- light.fibaro_system_fgd212_dimmer_2_level_2_0
- light.fibaro_system_fgd212_dimmer_2_level_3_0
- light.fibaro_system_fgd212_dimmer_2_step_size_2_6
- light.fibaro_system_fgd212_dimmer_2_step_size_3_6
None of them work when switching/clicking them in the HA user interface.
Since they work in the Razberry UI and the Fibaro relay works in the Home Assistant UI, I think I did not make any mistakes in my setup. Is there a configuration that I am overlooking?
