Hi Guys,
I try to integrate a smart implant to control my garage door too and having issue with it.
I have a sommer duo garage door.
I only connect the ground and Power on the input side and connect the output to the controlling opener.
I try your script but it is not working …
I have 2 switches: 1 is always on and the other allays off. If I try to switch the value, it comes back automatically to the previous value. In the log, I see that it consider the node dead …
2020-02-05 22:09:45.216 Detail, Node018, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-02-05 22:09:45.216 Detail, Node018, ZW_SEND_DATA delivered to Z-Wave stack
2020-02-05 22:09:49.318 Detail, Node018, Received: 0x01, 0x05, 0x00, 0x13, 0xe5, 0x01, 0x0d
2020-02-05 22:09:49.318 Detail, Node018, ZW_SEND_DATA Request with callback ID 0xe5 received (expected 0xe5)
2020-02-05 22:09:49.318 Info, Node018, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2020-02-05 22:09:49.318 Warning, Node018, WARNING: Device is not a sleeping node.
2020-02-05 22:09:49.318 Error, Node018, ERROR: node presumed dead
2020-02-05 22:09:49.318 Detail, Node001, Expected callbackId was received
2020-02-05 22:09:49.319 Detail, Node001, Expected reply was received
2020-02-05 22:09:49.319 Detail, Node001, Message transaction complete
2020-02-05 22:09:49.319 Detail, Node018, Removing current message
2020-02-05 22:09:49.319 Detail, Node018, Notification: Notification - Node Dead
2020-02-05 22:09:49.348 Error, Node018, ERROR: Dropping command because node is presumed dead
2020-02-05 22:09:49.348 Detail, Node018, Removing current message
2020-02-05 22:09:53.255 Info, Node018, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - True
2020-02-05 22:09:53.255 Info, Node018, SwitchBinary::Set - Setting node 18 to On
2020-02-05 22:09:53.255 Detail, Node018, Queuing (Send) MultiChannel Encapsulated (instance=1): SwitchBinaryCmd_Set (Node=18): 0x01, 0x0e, 0x00, 0x13, 0x12, 0x07, 0x60, 0x0d, 0x01, 0x05, 0x25, 0x01, 0xff, 0x25, 0xe7, 0x87
2020-02-05 22:09:53.255 Detail, Node018, Queuing (Send) MultiChannel Encapsulated (instance=1): SwitchBinaryCmd_Get (Node=18): 0x01, 0x0d, 0x00, 0x13, 0x12, 0x06, 0x60, 0x0d, 0x01, 0x05, 0x25, 0x02, 0x25, 0xe8, 0x76
2020-02-05 22:09:53.256 Error, Node018, ERROR: Dropping command because node is presumed dead
2020-02-05 22:09:53.256 Detail, Node018, Removing current message
I also notice that the smart implant is blinking in green and sends a lots to message:
2020-02-05 21:59:40.021 Info, Node018, Received a MultiChannelEncap from node 18, endpoint 5 for Command Class COMMAND_CLASS_SWITCH_BINARY
2020-02-05 21:59:40.021 Info, Node018, Received SwitchBinary report from node 18: level=Off
2020-02-05 21:59:40.021 Detail, Node018, Refreshed Value: old value=false, new value=false, type=bool
2020-02-05 21:59:40.021 Detail, Node018, Changes to this value are not verified
2020-02-05 21:59:40.021 Detail, Node018, Notification: ValueChanged
2020-02-05 21:59:41.360 Detail, Node018, Received: 0x01, 0x0d, 0x00, 0x04, 0x00, 0x12, 0x07, 0x60, 0x0d, 0x05, 0x00, 0x25, 0x03, 0x00, 0xad
2020-02-05 21:59:41.360 Info, Node018, Received a MultiChannelEncap from node 18, endpoint 5 for Command Class COMMAND_CLASS_SWITCH_BINARY
2020-02-05 21:59:41.360 Info, Node018, Received SwitchBinary report from node 18: level=Off
2020-02-05 21:59:41.360 Detail, Node018, Refreshed Value: old value=false, new value=false, type=bool
2020-02-05 21:59:41.360 Detail, Node018, Changes to this value are not verified
2020-02-05 21:59:41.360 Detail, Node018, Notification: ValueChanged
2020-02-05 21:59:42.698 Detail, Node018, Received: 0x01, 0x0d, 0x00, 0x04, 0x00, 0x12, 0x07, 0x60, 0x0d, 0x05, 0x00, 0x25, 0x03, 0x00, 0xad
2020-02-05 21:59:42.699 Detail,
2020-02-05 21:59:42.699 Info, Node018, Received a MultiChannelEncap from node 18, endpoint 5 for Command Class COMMAND_CLASS_SWITCH_BINARY
2020-02-05 21:59:42.699 Info, Node018, Received SwitchBinary report from node 18: level=Off
2020-02-05 21:59:42.699 Detail, Node018, Refreshed Value: old value=false, new value=false, type=bool
2020-02-05 21:59:42.699 Detail, Node018, Changes to this value are not verified
2020-02-05 21:59:42.699 Detail, Node018, Notification: ValueChanged
2020-02-05 21:59:53.202 Detail, Node018, Received: 0x01, 0x0d, 0x00, 0x04, 0x00, 0x12, 0x07, 0x60, 0x0d, 0x05, 0x00, 0x25, 0x03, 0x00, 0xad
2020-02-05 21:59:53.202 Info, Node018, Received a MultiChannelEncap from node 18, endpoint 5 for Command Class COMMAND_CLASS_SWITCH_BINARY
2020-02-05 21:59:53.202 Info, Node018, Received SwitchBinary report from node 18: level=Off
2020-02-05 21:59:53.202 Detail, Node018, Refreshed Value: old value=false, new value=false, type=bool
2020-02-05 21:59:53.202 Detail, Node018, Changes to this value are not verified
2020-02-05 21:59:53.202 Detail, Node018, Notification: ValueChanged
Did you guys having the behavior too ?
