Fibaro FGFS-101 flood sensor not triggered
I have a fibaro FGFS-101 flood sensor. Device is good included.
But the FIBARO System FGFS101 Zwave+ Flood Sensor Sensor is not triggered.
Anyone any suggestion?
If you didn’t include the node securely, you should set a security key in options.xml, copy the options.xml to the /.homeassistant/ folder, restart HASS and include the node using add_node_secure.
I did a secure include. Inclusions is okay.
Only the motion part is not triggered. Other sensor values change
Sounds as though the interview process may have not completed during inclusion. This would result in some functionality not working for the node. Best thing to do is to exclude it from your network and then include again. Ensuring that the device is close proximity to your primary controller or another mains powered node that supports inclusion.
I mean all the values in the screenshot are triggered only the last one not the FBFlood01 Sensor
http://i.imgur.com/nkMY7Du.png
Did you resolve this as I have exactly the same issue…it’s listed but doesn’t trigger
yes. The witt the follwing condition
condition: state
entity_id: sensor.flood1_flood
state: ‘2’
