I’m could get my Fibaro FGKF-601 working with home assistant…
But now I wanted to change de default behavior of the controller from every click sending a scene id and data, to one click send one data another click send another data for the scene id.
Lokking on the manual, i think that would be accomplished by changing the parameter 10. Single button associations - operating mode, I’m trying to change it from 0 to 2 (single click turns on, double click turns off)
I get the following on the log:
2018-04-18 00:18:27.536 Info, Node002, Value::Set - COMMAND_CLASS_CONFIGURATION - Scene activation for Square button - 21 - 1 - 2
2018-04-18 00:18:27.536 Info, Node002, Configuration::Set - Parameter=21, Value=2 Size=1
But the UI revert back after few seconds to “single click switches state to opposite”
Any idea what I might be doing wrong?
