I’ve switched over to Hassio, I’m not sure if this is a hardware issue or a hassio / z-wave config issue. For the last 2 weeksI’m going through batteries like crazy, I’ve reset to default and removed from hass and reinstalled. I’m at a loss, any ideas?
Here’s the node info:
averageRequestRTT: 23
averageResponseRTT: 8017
battery_level: 74
capabilities: routing,beaming
friendly_name: Fibaro
is_awake: false
is_failed: false
is_info_received: true
is_ready: true
is_zwave_plus: true
lastRequestRTT: 24
lastResponseRTT: 9016
manufacturer_name: FIBARO System
max_baud_rate: 40000
neighbors: 1,2,4
new_entity_id: zwave.fibaro
node_id: 3
node_name: Fibaro
old_entity_id: zwave.fibaro_3
product_name: FGMS001-ZW5 Motion Sensor
query_stage: Complete
receivedCnt: 175136
receivedDups: 3025
receivedTS: 2017-10-27 06:54:44:388
receivedUnsolicited: 175094
retries: 1
sentCnt: 72
sentFailed: 0
sentTS: 2017-10-27 06:02:40:845
wake_up_interval: 1
Tanks in advance for any help
