I have an issue with FGR223 Roller Switch.
It is visible in Home Assistant through Zwave JS, except that it works
When I try it in Zwave JS to MQTT and the the configuration panel I can trigger the Roller Switch and it works fine, except within Home Assistant itself
Other ZWave Devices such as lighting works fine…
I’m having the same problem, but with just one of my FGR223 shutter controllers.
I have two of these in my master suite (which is the farthest room regarding the raspberry pi location), and although both worked ok on the first boot, one of them is shown as unavailable.
With the old 1.4 ozw this was never an issue, as there are several neighbors that could serve as hop points. And as there is no way to explicitly heal the network, I am kind of in a dead-end.
