Fibaro FGS-224 double relay - second channel doesn’t update status
Guys, I have added a Fibaro device FGS224 in my zwave network which is a double relay. It has two individual loads controlled two switches S1 and S2. This is the successor of FGS223. The states of both switches are sent to the gateway correctly when they are operated by the software. The state of S1 is also sent to the gateway when it is operated using the switch. But when I try to operate S2 using the actual switch its state is never updated. I used zwave.change_association to change the association {“association”: “remove”, “node_id”: NN, “group”: 1, “target_node_id”:1} and then {“association”: “add”, “node_id”: NN, “group”: 1, “target_node_id”:1, “instance”:1} After that the state of S2 is sent correctly but the state of S1 is not i.e it is reversed
By the way the device is added in insecure mode.
Just to add more, I have re added the device as secure but I have the same behavior.
Does anyone have a similar issue with another device and have a suggestion? FGS-223 for example.
