I’ve been trying to troubleshoot why this relay has been causing me issues. Just general issues like not turning on with the motion sensor, or not updating the interface when it turns on or off. Looking int he logs, I see this when I turn it off using HA.
2019-10-19 13:50:23.293 Info, Node058, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - False
2019-10-19 13:50:23.293 Info, Node058, SwitchBinary::Set - Setting node 58 to Off
2019-10-19 13:50:23.294 Detail, Node058, Queuing (Send) SwitchBinaryCmd_Set (Node=58): 0x01, 0x0a, 0x00, 0x13, 0x3a, 0x03, 0x25, 0x01, 0x00, 0x25, 0xd5, 0x0b
2019-10-19 13:50:23.294 Detail, Node058, Queuing (Send) SwitchBinaryCmd_Get (Node=58): 0x01, 0x09, 0x00, 0x13, 0x3a, 0x02, 0x25, 0x02, 0x25, 0xd6, 0x09
2019-10-19 13:50:23.294 Info, Node058, Sending (Send) message (Callback ID=0xd5, Expected Reply=0x13) - SwitchBinaryCmd_Set (Node=58): 0x01, 0x0a, 0x00, 0x13, 0x3a, 0x03, 0x25, 0x01, 0x00, 0x25, 0xd5, 0x0b
2019-10-19 13:50:23.899 Detail, Node058, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-10-19 13:50:23.900 Detail, Node058, ZW_SEND_DATA delivered to Z-Wave stack
2019-10-19 13:50:27.911 Detail, Node058, Received: 0x01, 0x07, 0x00, 0x13, 0xd5, 0x00, 0x01, 0xce, 0xf1
2019-10-19 13:50:27.911 Detail, Node058, ZW_SEND_DATA Request with callback ID 0xd5 received (expected 0xd5)
2019-10-19 13:50:27.911 Info, Node058, Request RTT 4616 Average Request RTT 4441
2019-10-19 13:50:27.912 Detail, Node058, Removing current message
2019-10-19 13:50:27.912 Info, Node058, Sending (Send) message (Callback ID=0xd6, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=58): 0x01, 0x09, 0x00, 0x13, 0x3a, 0x02, 0x25, 0x02, 0x25, 0xd6, 0x09
2019-10-19 13:50:28.518 Detail, Node058, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-10-19 13:50:28.519 Detail, Node058, ZW_SEND_DATA delivered to Z-Wave stack
2019-10-19 13:50:32.312 Detail, Node058, Received: 0x01, 0x0d, 0x00, 0x04, 0x10, 0x3a, 0x07, 0x60, 0x0d, 0x01, 0x01, 0x25, 0x03, 0x00, 0x90
2019-10-19 13:50:32.312 Info, Node058, Response RTT 4400 Average Response RTT 5014
2019-10-19 13:50:32.312 Error, Node058, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_SWITCH_BINARY endpoint 1
2019-10-19 13:50:32.376 Detail, Node058, Received: 0x01, 0x0d, 0x00, 0x04, 0x10, 0x3a, 0x07, 0x60, 0x0d, 0x01, 0x01, 0x25, 0x03, 0x00, 0x90
2019-10-19 13:50:32.376 Info, Node058, Response RTT 4464 Average Response RTT 4739
2019-10-19 13:50:32.376 Error, Node058, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_SWITCH_BINARY endpoint 1
2019-10-19 13:50:32.773 Detail, Node058, Received: 0x01, 0x07, 0x00, 0x13, 0xd6, 0x00, 0x01, 0xe6, 0xda
2019-10-19 13:50:32.774 Detail, Node058, ZW_SEND_DATA Request with callback ID 0xd6 received (expected 0xd6)
2019-10-19 13:50:32.774 Info, Node058, Request RTT 4862 Average Request RTT 4651
2019-10-19 13:50:32.866 Detail, Node058, Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x3a, 0x0c, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x02, 0x21, 0x32, 0x00, 0x00, 0x00, 0x00, 0x91
2019-10-19 13:50:32.867 Info, Node058, Response RTT 4955 Average Response RTT 4847
2019-10-19 13:50:32.867 Error, Node058, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_METER endpoint 1
2019-10-19 13:50:37.912 Error, Node058, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-10-19 13:50:37.912 Detail, Node058, Removing current message
2019-10-19 13:50:37.913 Detail, Node058, Notification: Notification - TimeOut
So it seems there’s a problem with COMMAND_CLASS_METER in OpenZwave, and it’s causing the packet to be dropped as invalid. So the interface says it’s still on when the light has turned off.
This device also has 4800ms response time. I’m not sure if that error is a cause or a symptom. My mesh network is robust, and an extender is installed about 5 feet away. I have excluded it and repaired it in insecure mode to help latency, and it didn’t help.
