Fibaro FGS223 Zwave JS, using Scenes!
So here’s what may be a stupid question. I have Zwave JS configured in HASS OS using supervisor and i’ve added my nodes and everything seems to work flawlessly, which is impressive considering that last time i used the Deprecated ZWave integration i had huge delays and the states weren’t showing up correctly.
Now i’ve been trying to implement scenes using the Fibaro FGS-223 switches like 1/2/3 presses and hold but for the life of me i can’t figure out how to stop the button from actually shutting off my lights when i do this. I’ve set parameters 28 and 29 to enabled in the configuration screen for the device that i want to set, but when i press the button on the physical switch like 2-3 times it still turns off all the lights.
Any idea on how to fix this? I can’t apply a custom automation if all my smart bulbs are turned off.
Do i need to restart HA or anything after i configure the parameters on the Fibaro Switches? Am I doing something wrong?
I haven’t been able to get that to work with the FGS-223s either. It works fine with the FGD-212 dimmers, though. Of course they only do one channel, so I have a lot of dual in-wall switches with two FGD-212s behind them.
that’s disappointing to hear. has no one else encountered this issue? i find it hard to believe.
