I have a Fibaro FGSD002 smoke sensor together with an Aeon Labs Z-Stick (Gen 5). There are multiple entity_id’s but I can’t find anyone that reacts when testing the sensor. Anybody that knows what entity_id that is supposed to work or if I need to do some changes in e.g. OZCP?
The sensor is reacting yes (you do need to keep the button pressed for like 15 sec orso), and it makes quite a noise so keep a pillow at hand!.
HASS doesn’t seem to react on it though, that’s why I used the lid open/closed for testing stuff (like automatic opening of rollershutters).
When there is smoke (or the lid opens) I get a Telegram notification (in a telegram urgent bot. I also have a non urgent bot), all lights flash (the colored ones flash red) and then they stay on full brightness so I can find my way when it’s dark/smoke, and the rollershutters go up (so I might get out from that window and the thing is up in case power will fall out).
Later I might add other actions to the trigger.
Hopefully none of that all is ever needed!
Yes I have tested the self-test and got my ears destroyed. Good to know that you got info that HASS doesn’t react on it. Cool with the lights. I will at least configure for all lights on and some notifications. Trying Twilio SMS and Pushbullet for it.
I am having issues with state changes on my FGSD002 too. I see all the sensors in “states”, but the only fibaro sensor that updates is sensor.fibaro_system_fgsd002_smoke_sensor_temperature_2. Removing the lid triggers no change in sensor.fibaro_system_fgsd002_smoke_sensor_burglar_2. I seem to be missing something basic in my setup. This is one of my two first zwave devices. What am I missing here?
My sensor.aeotec_zw100_multisensor_6_burglar_3 does update.
Just a thought. Did you configure in OZWP that the sensor should report on for instance lid opening?
By default my sensor didn’t send any information via ZWAVE and I had to turn that on.
I can’t remember. At least I had to enable ZWAVE notifications. Perhaps that will be enough.
If needed I can send a printscreen of my settings, but that will be tomorrow or the day after.
You are right @PuckStar. Notifications are not enabled by default. Thank you!
I have now changed the notifications on my device, but I have not tested yet. Will test when I get home.
And @Jonas_Wikstrom I did not mean to highjack your thread here. We had the same problem
I had trouble with my Fibaro FGS-223, it didn’t show the correct state. I did a Reset and then I added the device in secure mode using OZWCP. After that it works like a charm!
Hi! Sorry for hijacking this thread… Have any tested this sensor with actual smoke or test gas? If I understand correctly Its the entity sensor.fibaro_system_fgsd002_smoke_sensor_smoke which should change state on smoke detection, but for some reason I have two entity ids for smoke: (3 is node id):
sensor.fibaro_system_fgsd002_smoke_sensor_smoke_3_1 (current state: 0)
sensor.fibaro_system_fgsd002_smoke_sensor_smoke_3_4 (current state: 254)
Anyone know the difference between these? The entity for heat also has two ids:
sensor.fibaro_system_fgsd002_smoke_sensor_heat_3_4 (current state: 0)
sensor.fibaro_system_fgsd002_smoke_sensor_heat_3_7 (current state: 254)
Hi Jonas, have you got it to work yet?
I also have a Fibaro FGSD002.
Added it (correctly I THINK), can see all the sensors and temperature reporting… but that seems to be it.
