Stop working in zwave js, flood sensor dont work to
Mine took a day to be discovered completely, seems to work now - how to trigger it ?
I’m getting more info than you, maybe you just have to wait a little longer.
Mine has firmware version 3.3 though.
My fibaro is the FGSS001 but its works in openzweave addon, in zwave js dont work
I just installed 3 of FGSD002 with firmware 3.3 on my Home Assistan (RPi 4 with Z-Wave JS integration and Z-Wave JS to MQTT using AEON Zstick Gen5)
All 3 of them act differently:
On first one I see temperature sensor and smoke and tempering, on second one I can see only temperature and 3rd is only associated and not interviewed form 7 hours now.
I added them without security. All sensors are in the reach of (green light after test on detector) zWave
Any Idea on what is wrong? I tried to press button to wake it up, tried to re-interview but no improvement.
Update - after several “3 short button pressed” and re-interview node commands I succeed to add devices full functional… I wander if the problem is in device, Aeon Z stick or in integration…
