I am using a Fibaro Plug FGWP102. And the basics is working fine.
But I have seen this plug showing a white LED on the LED ring when the plug is turned on.
But after I have included the plug on my HASS with Z-wave JS it will only show a short flash of white LED when it is being turned on and off.
In the Configuration V1 tab in the settings I can see the paramter (41) for LED color when On, but changing it doesn’t change anything on the Plug!
Looks like not many replies?
I have the same issue, but I’m lost.
I’ve tried it with my Aeotec 500, and it was working perfectly. But this was the faulty version so I went to get a 800 series, to be in the future, but now it doesn’t work. Also, I moved to JS UI instead of JS.
So not sure who is the bad guy here. Will test to go back to normal JS and see, but I don’t think it even add the device with JS, as the 800 series is by default on US frequency.
EDIT:
Just tried to remove the plug, remove JS UI, reinstall JS only, include the plug again, but same issue… I want to blame the controller.
EDIT 2: SOLVED:
I found out on another forum one thing, there is the menu on the device itself:
FIBARO Wall Plug has a MENU with each position indicated by the specified LED ring indicator colour.
In order to enter the menu press the B-button and hold for at least 2 seconds. While the B-button is still pressed, LED ring indicator colour will change in the following sequence:
WHITE – activate/deactivate LED ring indications
GREEN – reset the energy consumption data memory
VIOLET – initiate the Z-Wave network range test
YELLOW – reset the Wall Plug to factory defaults
Release the B-button to choose the desired function and confirm your choice with the B-button click.
I was able to fix it by using the WHITE option. So, press 2 seconds until the WHITE appear and release. Then, options are back working.
