I have a number of Z-Wave Fibaro wall-plugs (type FGWP102) in my setup. All are working fine, except for one - it doesn’t turn off.
If I turn it off in HA, then a second later, it turns back on. The logbook is showing a strange message: first comes the “turned off” event triggered by service switch.turn_off, then a second later comes the “turned on” event - also triggered by service switch.turn_off?
I’ve tried re-interviewing the wall plug in Z-Wave, but the issue is still present.
Does anyone have any idea what is going on? Thanks.
Version | core-2022.6.2 |
Installation Type | Home Assistant OS |
Development | false |
Supervisor | true |
Docker | true |
User | root |
Virtual Environment | false |
Python Version | 3.9.12 |
Operating System Family | Linux |
Operating System Version | 5.15.32-v8 |
CPU Architecture | aarch64 |
Timezone | Europe/Amsterdam |
Home Assistant Community Store
GitHub API | ok |
GitHub Content | ok |
GitHub Web | ok |
GitHub API Calls Remaining | 4935 |
Installed Version | 1.25.5 |
Stage | running |
Available Repositories | 1044 |
Downloaded Repositories | 10 |
Home Assistant Cloud
Logged In | true |
Subscription Expiration | 18 June 2022, 02:00 |
Relayer Connected | true |
Remote Enabled | true |
Remote Connected | true |
Alexa Enabled | true |
Google Enabled | true |
Remote Server | eu-central-1-2.ui.nabu.casa |
Reach Certificate Server | ok |
Reach Authentication Server | ok |
Reach Home Assistant Cloud | ok |
Home Assistant Supervisor
Host Operating System | Home Assistant OS 8.1 |
Update Channel | stable |
Supervisor Version | supervisor-2022.05.3 |
Agent Version | 1.2.1 |
Docker Version | 20.10.14 |
Disk Total | 228.5 GB |
Disk Used | 27.9 GB |
Healthy | true |
Supported | true |
Board | rpi4-64 |
Supervisor API | ok |
Version API | ok |
Installed Add-ons | Samba share (9.6.1), File editor (5.3.3), InfluxDB (4.4.1), Terminal & SSH (9.4.0), Grafana (7.5.2), Z-Wave JS to MQTT (0.42.0), TimescaleDB (2.0.1), Home Assistant Google Drive Backup (0.108.2), DSMR Reader (1.3.0) |
