[FIBARO FGWPE Wall plug] Can't show Energy (KWh) on my HA
Hello, :wink:
I’m on Home Assistant v 0.65.5 with Hassio.
In installed successfully a Fibaro Wall plug.
When I turn off the default_view: in the groups.yaml, I see the sensor called : sensor.fibaro_system_fgwpef_wall_plug_gen5_energy, so in KWh, and sensor sensor.fibaro_system_fgwpef_wall_plug_gen5_power, in W.
When I turn on my default_view:, my sensor ...energy in KWh disappears ! :thinking:
I specify that I see the _power sensor, and not _energy in the States menu.
My groups.yaml file :
  - sensor.fibaro_system_fgwpef_wall_plug_gen5_power
  - sensor.fibaro_system_fgwpef_wall_plug_gen5_energy
Thank you.
Up please. Somebody use the Energy (Kwh) sensor with a fibaro wall plug ?
Thank you ! :upside_down_face:
yes, its running perfectly fine:
eg_wohnzimmer_multimedia:
  entities:
    - switch.fgwpe_eg_wohnzimmer_switch
    - sensor.fgwpe_eg_wohnzimmer_power
    - sensor.fgwpe_eg_wohnzimmer_energy
product name: FGWPE/F Wall Plug Gen5
grafik
