Hi all,
first post here
I tried to seach about the problem I have but no luck. So here is my problem.
I started a brand new install of HA over Raspbian. I installed openzwave and plugged my Aeotec Z-Stick S5 and added the conf, so now I can see zwave device.
I added my first switch, a Fibaro FSG213 and I was able to see the switch.
It came out as a “switch”, no brand.
So i went down and I found my install was missing the proper .xml files for this device.
Wen to github and downloaded the fsg213.xml and updated the manucaturer*.xml
Removed and added again. Reboot.
Now I can see the switch as a Fibaro device, it get all the sensors, but I see the switch twice (actually 2 instances), one wornking and the other not.
I’ve tried to cleanup things but still no luck.
I removed the device
I uninstalled and reinstalled the openzwave package (removing files too)
I removed the zwcfg_*.xml file
I factory reset the USB Stick
Then I reconfigured everything, but as soon as I add the switch I have two instance, one is called “Switch” and is working (and is the one I expect to find) and a second instance called “FIBARO System FGS213 Switch” (with id switch.fibaro_system_fgs213_switch_switch_2_0_2) that I do not understand where it come from…
Some more info.
I found a copy of the files I added on forst steps in /srv/homeassistant/lib/python3.5/site-packages/python_openzwave/ozw_config
Is this a cache copy of the files under /etc/openzwave ?
Is there a way to clean it up?
Hey,
I am also seeing two instances for my FSG-213.
I believe this has to do with the two input ports of the FSG-213 (S1 and S2).
If you use it as a simple switch S2 is not connected, but you can use pulse contacts and set other behaviour in the FSG-213. For example set an action when long pressing. I have no use for advanced behaviours.
