Fibaro HC2 battery devices - how to see battery level?
I have Fibaro HC2 integrated with HA. I can see various posts regarding templates for battery level warnings, but my problem is I do not see battery level properties for my devices.
What I should do to see battery level for my fibaro devices connected to HC2?
Best regards,
Michał
Currently the fibaro integration does not follow the common pattern to expose battery level as entities. But each entity of a battery device has an attribute called battery_level which exposes the current battery state in %. Be aware that fibaro does report battery level as 255 when the battery is nearly empty instead of 0%.
Hope this helps.
I personally use the battery-entity-row add-on (installed via HACS) to show the battery state in the dashboard.
Configuration is then like:
entities:
  - type: custom:battery-entity-row
    entity: binary_sensor.flur_wc_eingang_bewegung_160
    attribute: battery_level
type: entities
