Fibaro HC2 change IP
Hello, I’m updating/changing my network, and Fibaro HC2 ip has changed, and I can’t find a way to update it on HA Fibaro integration. On HA wiki only have a note saying:
It is recommended to assign a static IP address to your Fibaro controller. This ensures that it won’t change its IP address, so you won’t have to change the url if the controller reboots and comes up with a different IP address. See your router’s manual for details on how to set this up. If you need the MAC address of your Fibaro, check the label on the bottom.
But I can’t find the way to change the url
If anybody knows and want to help I’ll be grateful.
Thanks.
this is currently not possible in the UI.
If you like to change it manually you can do that in the file config/.storage/core.config_entries and restart afterwards HA. (e.g. with the Terminal & SSH add-on)
Otherwise just remove and add the integration again with the new IP address.
Hope that helps.
