Fibaro Heat Controller FGT001 added twice
Hello, I have 6 Fibaro FGT001 heat controllers with latest firmware 4.07. The issue I have is when I add one device it is visible once at zwave control panel, but on HA devices tab I see two heat controllers with two batteries. The duplicated items with “_2”, and those are handled as separate device:
sensor.fibaro_system_fgt001_heat_controller_alarm_level
sensor.fibaro_system_fgt001_heat_controller_alarm_level_2
sensor.fibaro_system_fgt001_heat_controller_alarm_type
sensor.fibaro_system_fgt001_heat_controller_alarm_type_2
sensor.fibaro_system_fgt001_heat_controller_battery_level
sensor.fibaro_system_fgt001_heat_controller_battery_level_2
climate.fibaro_system_fgt001_heat_controller_mode
sensor.fibaro_system_fgt001_heat_controller_power_management
sensor.fibaro_system_fgt001_heat_controller_power_management_2
sensor.fibaro_system_fgt001_heat_controller_sourcenodeid
sensor.fibaro_system_fgt001_heat_controller_sourcenodeid_2
sensor.fibaro_system_fgt001_heat_controller_system
sensor.fibaro_system_fgt001_heat_controller_temperature
The problem related with that - I can’t set up temperature on dashboard, it just reads the setting made on the device itself.
I am using Sigma Designs, Inc. Aeotec Z-Stick Gen5 (ZW090) - UZB
I’ve collected the logs from device add, but it contain huge amount of lines, so I will paste this to pastebin:
I have latest docker image 0.118.3
Many thanks for help!
I can only say, I have the same thing…
Known issue?
