This topic in an umbrella for discussing the existing Fibaro HC3 and Home Assistant integration - GitHub - alexander-vitishchenko/hc3-to-mqtt: Fibaro HC3 integration with Home Assistant & NodeRed
Key features:
- Device support for RGBW + dimmer + binary lights, Remote Controllers, Energy API that has been announced by Home Assistant recently, most switches, thermostats, binary and multi-level sensors, shutters/covers
- Bi-directional integration
- Ability to detect new devices during QuickApp runtime, not only during startup. Ability to track and propagate Device configuration changes and Device removal events to Home Assistant during QA runtime
- Simplified setup with no username/password required for HC3 authentication
- Ability to setup MQTT credentials, or use it in a passwordless mode
- High performance by using Fibaro HC3 async pull requests
