I’m using version 2021.2.3.
I have a Fibaro Implant sensor, which I use to monitor the temp in my pond. At times when it’s windy out, I get impossible peaks on the temp.
In the image below, I have heaters that keep the pond at 69 degrees. But last night when it was windy, and maybe the box housing the Implant moved a bit. But the reading went from 69 to over 90 degrees for an observation, then down to normal. Even if it was a good temp, it couldn’t change that fast, as the heaters can only do a degree an hour or so.
So is this an issue with HA or an issue with the the Fibaro sensor?
Thanks,
Ambi
