So… noticed openzwave had it added and decided to purchase.
Tried to set it up yesterday, but ran in to problems of course
It get’s recognized and is configurable in openzwave. So far so good, but key presses return like this:
2017-03-14 20:46:14.888 Detail, Node020, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x14, 0x02, 0x98, 0x40, 0x3d
2017-03-14 20:46:14.888 Info, Node020, Received SecurityCmd_NonceGet from node 20
2017-03-14 20:46:14.888 Info, NONCES: 0x1c, 0x9a, 0x4b, 0xee, 0x59, 0x3e, 0x6b, 0x53
2017-03-14 20:46:14.888 Info, NONCES: 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
2017-03-14 20:46:14.888 Info, Node020, Sending (Send) message (Callback ID=0x01, Expected Reply=0x00) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x14, 0x0a, 0x98, 0x80, 0x1c, 0x9a, 0x4b, 0xee, 0x59, 0x3e, 0x6b, 0x53, 0x05, 0x01, 0x83:
2017-03-14 20:46:14.897 Detail, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-03-14 20:46:14.897 Detail, ZW_SEND_DATA delivered to Z-Wave stack
2017-03-14 20:46:14.913 Detail, Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x00, 0x02, 0xe8
2017-03-14 20:46:14.914 Detail, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2017-03-14 20:46:14.934 Detail, Node020, Received: 0x01, 0x1f, 0x00, 0x04, 0x00, 0x14, 0x19, 0x98, 0x81, 0xe7, 0x5c, 0xda, 0x19, 0x07, 0x9c, 0xe0, 0x05, 0x8a, 0x85, 0xf4, 0x02, 0xe3, 0x67, 0x1c, 0x38, 0x47, 0x22, 0x0c, 0x31, 0x44, 0x8a, 0x25, 0x1c
2017-03-14 20:46:14.934 Info, Raw: 0x98, 0x81, 0xe7, 0x5c, 0xda, 0x19, 0x07, 0x9c, 0xe0, 0x05, 0x8a, 0x85, 0xf4, 0x02, 0xe3, 0x67, 0x1c, 0x38, 0x47, 0x22, 0x0c, 0x31, 0x44, 0x8a, 0x25, 0x1c
2017-03-14 20:46:14.934 Detail, Node020, Decrypted Packet: 0x00, 0x5b, 0x03, 0x08, 0x80, 0x02
2017-03-14 20:46:14.934 Info, Node020, Received Central Scene set from node 20: scene id=2 in 7680 seconds. Sending event notification.
2017-03-14 20:46:14.934 Warning, Node020, No ValueID created for Scene 2
So, No ValueID created. This goes for every press/sequence/button.
On searching this I came across this pull request:
So I pulled python-openzwave, applied the above patches and recompiled. Only to have the same results.
Does someone have this working? Not looking forward to throwing the keyfob in a drawer for a long time as it would be a nifty thing to get working in HA.
