First off, I cannot take credit for this Blueprint. I used jiri.arazim blueprint and edited it to work for the event types I was getting.
This blueprint works with the Fibaro Keyfob remote and has support for button presses, and holding down each button. First select your device and then pass in what actions you want to happen.
blueprint:
description: Create automations for the Fibaro Keyfob
domain: automation
input:
keyfob_device:
description: A KeyFob device.
selector:
device:
integration: zwave_js
manufacturer: Fibargroup
model: FGKF601
button_1_pressed:
name: Button 1 (square) Pressed
description: Actions to run when button 1 (square) is pressed.
default: []
selector:
button_1_held:
name: Button 1 (square) Held Down
description: Actions to run when button 1 (square) is held down.
default: []
selector:
button_2_pressed:
name: Button 2 (circle) Pressed
description: Actions to run when button 2 (circle) is pressed.
default: []
selector:
button_2_held:
name: Button 2 (circle) Held Down
description: Actions to run when button 2 (circle) is held down.
default: []
selector:
button_3_pressed:
name: Button 3 (cross) Pressed
description: Actions to run when button 3 (cross) is pressed.
default: []
selector:
button_3_held:
name: Button 3 (cross) Held Down
description: Actions to run when button 3 (cross) is held down.
default: []
selector:
button_4_pressed:
name: Button 4 (triangle) Pressed
description: Actions to run when button 4 (triangle) is pressed.
default: []
selector:
button_4_held:
name: Button 4 (triangle) Held Down
description: Actions to run when button 4 (triangle) is held down.
default: []
selector:
button_5_pressed:
name: Button 5 (minus) Pressed
description: Actions to run when button 5 (minus) is pressed.
default: []
selector:
button_5_held:
name: Button 5 (minus) Held Down
description: Actions to run when button 5 (minus) is held down.
default: []
selector:
button_6_pressed:
name: Button 6 (plus) Pressed
description: Actions to run when button 6 (plus) is pressed.
default: []
selector:
button_6_held:
name: Button 6 (plus) Held Down
description: Actions to run when button 6 (plus) is held down.
default: []
selector:
mode: single
max_exceeded: silent
platform: event
event_type: zwave_js_value_notification
event_data:
device_id: !input keyfob_device
command_class_name: "Central Scene"
- variables:
action_name: "{{ trigger.event.data.value_raw }}"
property_key: "{{ trigger.event.data.property_key }}"
- choose:
- conditions: "{{ action_name == 0 and property_key == '001'}}"
sequence: !input button_1_pressed
- conditions: "{{ action_name == 2 and property_key == '001' }}"
sequence: !input button_1_held
- conditions: "{{ action_name == 0 and property_key == '002' }}"
sequence: !input button_2_pressed
- conditions: "{{ action_name == 2 and property_key == '002' }}"
sequence: !input button_2_held
- conditions: "{{ action_name == 0 and property_key == '003' }}"
sequence: !input button_3_pressed
- conditions: "{{ action_name == 2 and property_key == '003' }}"
sequence: !input button_3_held
- conditions: "{{ action_name == 0 and property_key == '004' }}"
sequence: !input button_4_pressed
- conditions: "{{ action_name == 2 and property_key == '004' }}"
sequence: !input button_4_held
- conditions: "{{ action_name == 0 and property_key == '005' }}"
sequence: !input button_5_pressed
- conditions: "{{ action_name == 2 and property_key == '005' }}"
sequence: !input button_5_held
- conditions: "{{ action_name == 0 and property_key == '006' }}"
sequence: !input button_6_pressed
- conditions: "{{ action_name == 2 and property_key == '006' }}"
sequence: !input button_6_held
