I’m very new to Home Assistant after having used Openhab for several years so please bear with me! I have an old Fibaro Motion Sensor (FGMS-001) Application Version 2.07 that I’m trying to use with HA. Unfortunately I cannot get the motion sensor to work properly. It behaves differently depending on if I use the built in Z-Wave or Open Z-Wave.
With the built in Z-Wave integration the motion binary sensor doesn’t turn on with motion. Sometimes if I press the button 3 times it will come on and go off after the set delay correctly but without the button it does not come on. I see the following in the logs when it detects motion but the entity never updates:
2020-07-15 00:24:25.165 Detail, Node005, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x05, 0x03, 0x30, 0x03, 0xff, 0x38
2020-07-15 00:24:25.165 Info, Node005, Received SensorBinary report: Sensor:56 State=On
2020-07-15 00:24:25.165 Detail, Node005, Refreshed Value: old value=false, new value=true, type=bool
2020-07-15 00:24:25.165 Detail, Node005, Changes to this value are not verified
2020-07-15 00:24:25.165 Detail, Node005, Notification: ValueChanged
2020-07-15 00:24:25.271 Detail, Node005, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x05, 0x03, 0x20, 0x01, 0x00, 0xd5
2020-07-15 00:24:25.271 Info, Node005, Received Basic set from node 5: level=0. Treating it as a Basic report.
2020-07-15 00:24:25.272 Detail, Node005, Queuing (WakeUp) SensorBinaryCmd_Get (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x30, 0x02, 0x25, 0x4f, 0xba
2020-07-15 00:24:25.272 Detail, Node005, Refreshed Value: old value=true, new value=false, type=bool
2020-07-15 00:24:25.272 Detail, Node005, Changes to this value are not verified
2020-07-15 00:24:25.272 Detail, Node005, Notification: ValueChanged
Interestingly, when it recieves an off report the sensor is 199 rather than 56, could this be anything to do with it?
If I use open z-wave I get the entity updating to on correctly but it immediatly goes back to off, regardless of the sensor delay set on the device.
I hope someone can help as I’m pulling my hair out with this one. It always worked correctly in Openhab so I know the sensor itself is ok.
Chris
