The config options show up for me, but I needed to grab the latest OZW device config files from the OpenZWave Github repository. Here’s my section of the zwcfg_*.xml, as @xtensa said you can replace the command class 112 section of your file with mine.
<CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1" request_flags="5" innif="true">
<Instance index="1" />
<Value type="list" genre="config" instance="1" index="1" label="On Off Status After Power Failure" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="2" vindex="0" size="1">
<Help>On Off Status After Power Failure. Default: forced to OFF</Help>
<Item label="forced to OFF" value="0" />
<Item label="restore to previous state" value="1" />
<Item label="forced to on" value="2" />
</Value>
<Value type="list" genre="config" instance="1" index="20" label="Switch / Input Type for IN1" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="4" vindex="2" size="1">
<Help>Switch / Input Type for IN1. Choose the input/switch type you want to connect to the IN1 terminal. Default: momentary switch</Help>
<Item label="analog sensor w/no pullup" value="0" />
<Item label="analog sensor with pull-up" value="1" />
<Item label="momentary switch" value="2" />
<Item label="toggle switch (on when swithc is on)" value="3" />
<Item label="toggle switch (toggles with switch toggle)" value="4" />
</Value>
<Value type="list" genre="config" instance="1" index="21" label="Switch / Input Type for IN2" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="4" vindex="2" size="1">
<Help>Switch / Input Type for IN2. Choose the input/switch type you want to connect to the IN2 terminal. Default: momentary switch</Help>
</Value>
<Value type="list" genre="config" instance="1" index="22" label="Switch / Input Type for IN3" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="4" vindex="2" size="1">
<Help>Switch / Input Type for IN3. Choose the input/switch type you want to connect to the IN3 terminal. Default: momentary switch</Help>
</Value>
<Value type="list" genre="config" instance="1" index="23" label="Switch / Input Type for IN4" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="4" vindex="2" size="1">
<Help>Switch / Input Type for IN4. Choose the input/switch type you want to connect to the IN4 terminal. Default: momentary switch</Help>
</Value>
<Value type="short" genre="config" instance="1" index="40" label="Scene Control for IN1" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="15" value="False">
<Help>Assign scene activation trigger for IN1 terminal. Enter the sum of values to enable more than 1 trigger.Values: 0 – scene control disabled. 1 – click / toggle the connected switch once to trigger a scene; 2 – click / toggle the connected switch twice to trigger a scene; 4 – click / toggle the connected switch 3 times to trigger a scene; 8 – hold and release the connected momentary switch to trigger a scene. Default: 15</Help>
</Value>
<Value type="short" genre="config" instance="1" index="41" label="Scene Control for IN2" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="15" value="False">
<Help>Assign scene activation trigger for IN2 terminal. Enter the sum of values to enable more than 1 trigger.Values: 0 – scene control disabled. 1 – click / toggle the connected switch once to trigger a scene; 2 – click / toggle the connected switch twice to trigger a scene; 4 – click / toggle the connected switch 3 times to trigger a scene; 8 – hold and release the connected momentary switch to trigger a scene. Default: 15</Help>
</Value>
<Value type="short" genre="config" instance="1" index="42" label="Scene Control for IN3" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="15" value="False">
<Help>Assign scene activation trigger for IN3 terminal. Enter the sum of values to enable more than 1 trigger.Values: 0 – scene control disabled. 1 – click / toggle the connected switch once to trigger a scene; 2 – click / toggle the connected switch twice to trigger a scene; 4 – click / toggle the connected switch 3 times to trigger a scene; 8 – hold and release the connected momentary switch to trigger a scene. Default: 15</Help>
</Value>
<Value type="short" genre="config" instance="1" index="43" label="Scene Control for IN4" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="15" value="False">
<Help>Assign scene activation trigger for IN4 terminal. Enter the sum of values to enable more than 1 trigger.Values: 0 – scene control disabled. 1 – click / toggle the connected switch once to trigger a scene; 2 – click / toggle the connected switch twice to trigger a scene; 4 – click / toggle the connected switch 3 times to trigger a scene; 8 – hold and release the connected momentary switch to trigger a scene. Default: 15</Help>
</Value>
<Value type="short" genre="config" instance="1" index="62" label="Power Report Frequency" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="32400" value="3600">
<Help>Power Report Frequency. Choose how often you want your RGBW Dimmer to report power consumption (W) to your controller. NOTE: must be 0, or an increment of 30. Default: 3600</Help>
</Value>
<Value type="short" genre="config" instance="1" index="65" label="Energy Report Threshold" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="500" value="10">
<Help>Energy Report Threshold. Choose how you want your RGBW Dimmer to report energy use (kWh) to your hub. The number entered as value corresponds to decimal values in energy useage change. So if 10 is entered by default, the RGBW Dimmer will report any change in energy use over 0.1 kWh. Energy reports are sent in t least 30-second intervals.</Help>
</Value>
<Value type="short" genre="config" instance="1" index="66" label="Energy Report Frequency" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="32400" value="3600">
<Help>Energy Report Frequency. Choose how often you want your RGBW Dimmer to report energy (kWh) to your controller. NOTE: must be 0, or an increment of 30. Default: 3600</Help>
</Value>
<Value type="list" genre="config" instance="1" index="150" label="RGBW/HSB Wall Switch Mode" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="1" vindex="0" size="1">
<Help>RGBW/HSB Wall Switch Mode. Choose how switches connected to the input terminals control your LED strip. In the default RGBW mode, each switch connected to each input terminal controls the RGBW chnnels separately (so IN1 for red, IN2 for green, etc.) with a single click for ON/OFF, double click to full brightness, and press-and-hold to dim (momentary switches only). In the HSB, IN1 controls hue, IN2 - saturation, IN3 - brightness, IN4 - white with single click for last set value or value 0, double click to max value, and press-and-hold to set custom value. Default: RGBW mode</Help>
<Item label="RGBW mode" value="0" />
<Item label="HSB mode" value="1" />
</Value>
<Value type="short" genre="config" instance="1" index="151" label="Ramp Rate (switch)" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="127" value="3">
<Help>Ramp Rate (switch). Adjust the ramp rate for your RGBW dimmer (fade-in/fade-out effect for on/off operation). Values correspond to the number of seconds it takes for the dimmer to reach full brightness or turn off when operated from the connected wall switch. Note that 0 is instant on/off. Default : 3 seconds</Help>
</Value>
<Value type="short" genre="config" instance="1" index="152" label="Ramp Rate (Z-Wave)" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="127" value="1">
<Help>Ramp Rate (Z-Wave). Adjust the ramp rate for your RGBW dimmer (fade-in/fade-out effect for on/off operation). Values correspond to the number of seconds it takes for the dimmer to reach full brightness or turn off when operated remotely from the Z-Wave hub Note that 0 is instant on/off. Default : 3 seconds</Help>
</Value>
<Value type="list" genre="config" instance="1" index="157" label="Preset Programs" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="10" vindex="2" size="1">
<Help>Enable one of the preset animated color programs to set the mood with a click. Default: preset programs disabled</Help>
<Item label="preset programs disabled" value="0" />
<Item label="fireplace" value="6" />
<Item label="storm" value="7" />
<Item label="rainbow" value="8" />
<Item label="polar lights" value="9" />
<Item label="police" value="10" />
</Value>
</CommandClass>
