Thanks for this! I have Fibaro RGBW Controller 2 (FGRBBW-442). I have followed the above instructions for Zooz ZEN31 and it kind of works for the Fibaro. I get all the entities that I should, but I cannot access the configuration parameters. For example, I cannot change parameter 20 from 2 (default) to 4. The list of configuration parameters in Home Assistant/Zwave is completely empty for this node. Also, I have tried with zwave.set_config_parameter but this also seems not to work: no error message but does not change the behavior as it should. Any ideas?
Open zwcfg_*.xml and check command class 112 for this device. It must be empty if you dont see any options. Place all configuration definitions here. Of course you need to restart HA core after the change.
The config options show up for me, but I needed to grab the latest OZW device config files from the OpenZWave Github repository. Hereās my section of the zwcfg_*.xml, as @xtensa said you can replace the command class 112 section of your file with mine.
<CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1" request_flags="5" innif="true">
<Instance index="1" />
<Value type="list" genre="config" instance="1" index="1" label="On Off Status After Power Failure" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="2" vindex="0" size="1">
<Help>On Off Status After Power Failure. Default: forced to OFF</Help>
<Item label="forced to OFF" value="0" />
<Item label="restore to previous state" value="1" />
<Item label="forced to on" value="2" />
</Value>
<Value type="list" genre="config" instance="1" index="20" label="Switch / Input Type for IN1" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="4" vindex="2" size="1">
<Help>Switch / Input Type for IN1. Choose the input/switch type you want to connect to the IN1 terminal. Default: momentary switch</Help>
<Item label="analog sensor w/no pullup" value="0" />
<Item label="analog sensor with pull-up" value="1" />
<Item label="momentary switch" value="2" />
<Item label="toggle switch (on when swithc is on)" value="3" />
<Item label="toggle switch (toggles with switch toggle)" value="4" />
</Value>
<Value type="list" genre="config" instance="1" index="21" label="Switch / Input Type for IN2" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="4" vindex="2" size="1">
<Help>Switch / Input Type for IN2. Choose the input/switch type you want to connect to the IN2 terminal. Default: momentary switch</Help>
</Value>
<Value type="list" genre="config" instance="1" index="22" label="Switch / Input Type for IN3" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="4" vindex="2" size="1">
<Help>Switch / Input Type for IN3. Choose the input/switch type you want to connect to the IN3 terminal. Default: momentary switch</Help>
</Value>
<Value type="list" genre="config" instance="1" index="23" label="Switch / Input Type for IN4" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="4" vindex="2" size="1">
<Help>Switch / Input Type for IN4. Choose the input/switch type you want to connect to the IN4 terminal. Default: momentary switch</Help>
</Value>
<Value type="short" genre="config" instance="1" index="40" label="Scene Control for IN1" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="15" value="False">
<Help>Assign scene activation trigger for IN1 terminal. Enter the sum of values to enable more than 1 trigger.Values: 0 ā scene control disabled. 1 ā click / toggle the connected switch once to trigger a scene; 2 ā click / toggle the connected switch twice to trigger a scene; 4 ā click / toggle the connected switch 3 times to trigger a scene; 8 ā hold and release the connected momentary switch to trigger a scene. Default: 15</Help>
</Value>
<Value type="short" genre="config" instance="1" index="41" label="Scene Control for IN2" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="15" value="False">
<Help>Assign scene activation trigger for IN2 terminal. Enter the sum of values to enable more than 1 trigger.Values: 0 ā scene control disabled. 1 ā click / toggle the connected switch once to trigger a scene; 2 ā click / toggle the connected switch twice to trigger a scene; 4 ā click / toggle the connected switch 3 times to trigger a scene; 8 ā hold and release the connected momentary switch to trigger a scene. Default: 15</Help>
</Value>
<Value type="short" genre="config" instance="1" index="42" label="Scene Control for IN3" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="15" value="False">
<Help>Assign scene activation trigger for IN3 terminal. Enter the sum of values to enable more than 1 trigger.Values: 0 ā scene control disabled. 1 ā click / toggle the connected switch once to trigger a scene; 2 ā click / toggle the connected switch twice to trigger a scene; 4 ā click / toggle the connected switch 3 times to trigger a scene; 8 ā hold and release the connected momentary switch to trigger a scene. Default: 15</Help>
</Value>
<Value type="short" genre="config" instance="1" index="43" label="Scene Control for IN4" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="15" value="False">
<Help>Assign scene activation trigger for IN4 terminal. Enter the sum of values to enable more than 1 trigger.Values: 0 ā scene control disabled. 1 ā click / toggle the connected switch once to trigger a scene; 2 ā click / toggle the connected switch twice to trigger a scene; 4 ā click / toggle the connected switch 3 times to trigger a scene; 8 ā hold and release the connected momentary switch to trigger a scene. Default: 15</Help>
</Value>
<Value type="short" genre="config" instance="1" index="62" label="Power Report Frequency" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="32400" value="3600">
<Help>Power Report Frequency. Choose how often you want your RGBW Dimmer to report power consumption (W) to your controller. NOTE: must be 0, or an increment of 30. Default: 3600</Help>
</Value>
<Value type="short" genre="config" instance="1" index="65" label="Energy Report Threshold" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="500" value="10">
<Help>Energy Report Threshold. Choose how you want your RGBW Dimmer to report energy use (kWh) to your hub. The number entered as value corresponds to decimal values in energy useage change. So if 10 is entered by default, the RGBW Dimmer will report any change in energy use over 0.1 kWh. Energy reports are sent in t least 30-second intervals.</Help>
</Value>
<Value type="short" genre="config" instance="1" index="66" label="Energy Report Frequency" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="32400" value="3600">
<Help>Energy Report Frequency. Choose how often you want your RGBW Dimmer to report energy (kWh) to your controller. NOTE: must be 0, or an increment of 30. Default: 3600</Help>
</Value>
<Value type="list" genre="config" instance="1" index="150" label="RGBW/HSB Wall Switch Mode" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="1" vindex="0" size="1">
<Help>RGBW/HSB Wall Switch Mode. Choose how switches connected to the input terminals control your LED strip. In the default RGBW mode, each switch connected to each input terminal controls the RGBW chnnels separately (so IN1 for red, IN2 for green, etc.) with a single click for ON/OFF, double click to full brightness, and press-and-hold to dim (momentary switches only). In the HSB, IN1 controls hue, IN2 - saturation, IN3 - brightness, IN4 - white with single click for last set value or value 0, double click to max value, and press-and-hold to set custom value. Default: RGBW mode</Help>
<Item label="RGBW mode" value="0" />
<Item label="HSB mode" value="1" />
</Value>
<Value type="short" genre="config" instance="1" index="151" label="Ramp Rate (switch)" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="127" value="3">
<Help>Ramp Rate (switch). Adjust the ramp rate for your RGBW dimmer (fade-in/fade-out effect for on/off operation). Values correspond to the number of seconds it takes for the dimmer to reach full brightness or turn off when operated from the connected wall switch. Note that 0 is instant on/off. Default : 3 seconds</Help>
</Value>
<Value type="short" genre="config" instance="1" index="152" label="Ramp Rate (Z-Wave)" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="127" value="1">
<Help>Ramp Rate (Z-Wave). Adjust the ramp rate for your RGBW dimmer (fade-in/fade-out effect for on/off operation). Values correspond to the number of seconds it takes for the dimmer to reach full brightness or turn off when operated remotely from the Z-Wave hub Note that 0 is instant on/off. Default : 3 seconds</Help>
</Value>
<Value type="list" genre="config" instance="1" index="157" label="Preset Programs" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="10" vindex="2" size="1">
<Help>Enable one of the preset animated color programs to set the mood with a click. Default: preset programs disabled</Help>
<Item label="preset programs disabled" value="0" />
<Item label="fireplace" value="6" />
<Item label="storm" value="7" />
<Item label="rainbow" value="8" />
<Item label="polar lights" value="9" />
<Item label="police" value="10" />
</Value>
</CommandClass>
Thanks! Now it seems to work
FYI, seems like your 112 section is not updated with what is described in the Fibaro manual (v1.1). For example, parameters 40-43 are not boolean, but short integers.
Hi. Thank for all contributions. I was able to get Fibaro RGBW 2 (FGRGBW-442) working (kind of) with these instructions including config options. The problem I am having is with HA not getting the states updated so the toggles are all messed up. Was anyone able to get the states reflected in HA properly? Thank you
In my case the states are working correctly.
I was having that issue as well. The device has a ramp rate parameter, and it seems the update value catches it when it is in the middle of ramping.
Two ways I can think of to fix it.
Refresh the entity with a zwave service call (what I did, I can confirm it works): https://www.home-assistant.io/docs/z-wave/services/
Add a delay in your config file: Dimmer lights show as 'on' even when turned off
@HA_jr, good catch. The Zooz ZEN31 openzwave device file I took from github must be wrong. I updated my file above.
@DaveCo1701 thanks for the suggestions. Not only I get the values in the middle of ramping, but when I toggle the physical switch, HA does not update at all. I can see the ValueChanged event in the OZW log but HA does not seem to do anything with it.
I could not get the delay option to work either. I now use refresh_entity zwave service call in an automation that triggers on the power entity state change from the device. It is not ideal but it updates the entities properly within a few seconds.
Is there anyone that got this Fibaro RGBW-2 controller working correctly with OpenZwave(beta) ?
I was shipped with as 442 instead of a 441 aswell:
Is there a step-by-step guide to get it working properly?
Anyone that made any progress with this device ?
I created a step-by-step tutorial here:
Iām kind of late, Thanks for the tutorial, will use it when needed as iāve replaced the fibaro with a qbino for now
Was anyone able to sucessfully use the device with the new ZwaveJS Integration (not ZWave-to-MQTT)? In there at least the device was detected, but I have several color wheels (seems like one for each channel) but nothing works⦠just wondering if anyone managed to operate the device with the new integration.
This is a known issueā¦
At the moment, the ZwaveJS integration only recognises 5 light channel entities, instead of the 6 that it should have. The missing one is the one that would show the color wheel if it were present.
See:
Well, the issue has been closed but obviously without resolving it then. I already asked in there to reopen it or if the 442 device is also affected. So far I didnāt get a response and the ticked still remains closed but not resolved⦠strangeā¦
Hello, for me, it works for the 442, not for the 441. (version 2021.4.4)
Regards,
Bart
What exactly did you do to make it work? For me, the same versions do not lead to success and I still cannot get the 442 device to operate as it should.
