Using parameter 14 it is possible to configure the Fibaro FGRGBWM441 RGBW controller inputs as sensors. Like this:
I’ve tried this, but don’t see any new sensor entities appearing under the rgbw zwave node. But I’m not sure what to expect, really. Anyone have any experience with this?
I have it partelly working only UI and entity is not correct, the voltage that I apply on an input is presented as brightness in the light entity of the RGBW controller. 0% 0V - 100% 10 V
Does anyone have some suggestions on how to change this to a sensor entity?
I played with this a long time ago, think I had to set parameter 14 to something based on the table in the manual. I can’t remember how you come up with the number though (default 4369 (1111 Hex))
Look here, it’s the calculator I used to generate paramter 14 to add to the zwave config panel
I think i have configured that part correctly, for configuring all four as analog input its 34952 (0x8888).
In HA I have to set: -30584 because its expecting a int16 instead of a uint16.
I think its configured correctly because when I apply for example 1.5V to a input I see the brightness change to 15% and if I connect nothing it go back to 100% (this is probably because there is a pul-up to 10V on the input) so my conclusion was that the inputs are configured I only don’t know how I can get a separate sensor entity for those inputs ( I already restart everything and reconnect but that din’t help)
P.S. I just started with HA so I don’t have much experience with the platform yet. (still learning)
For reference; in OZWadmin, it also takes values as signed, so -30854, to set 34952, which is 0x8888 (all inputs 0-10v).
I did try other variants (input 1 only -32495/33041), but that did not update the Red (input 1) channel (which was INSTANCE 3 in the OZWadmin User Values tab)
So eventhough i could finally read the 0-10v sensor values, it is of no use to be becuase that mode forces the RGB values to match, where I wanted to use the RGB controller as a controller, and utilitise the 0-10v sensor as a bonus, which seems not to be the case.
