FIBARO RGBW delay 7 sec?!
Hi!
Got 3 FIBARO RGBW switches.
2 connected to fans and 1 to a LED strip. They work ok.
The one that is connected to a the LED is turning on instantly but color/dimming/turn off is delayed.
The longer I am playing with the switch the longer the delay.
Its setup as a RGBW normal color control start/stop.
Any suggestions? Settings? I healed the network and all that stuff.
Just give my solution if someone had the same problem. I got every z wave nodes offline. Added all one by one and then it solved itself. A possible zwave network routing error.
It’s gone and all is fine.
