Upgrade to the latest release of HA.
Thank you!
Now it works.
Not sure if it is related but got a heads up about Zwave JS that device 6 wasn’t available
I don’t have the current status since I have not yet migrated
Just hit this as well ! Anyone know of any updates? re Device#6 missing on the Fibaro RGBW ?
I have not taken the step to migrate but thaks for letting us know about it is still an issue.
If you do some progress please post that as well
Since I upgraded HA and reinterviewed the nodes, I’m seeing the 6 devices on both versions of the Fibaro RGBW controllers.
Hi Geoff … I am tearing my hair out as I re-interviewed and only see 5 devices… just to confirm … you are able to select the police siren etc pre-built light routines?
I don’t use the built-in light routines, so I’ve not checked this. Here’s what I see in HA for the RGBW controller:
Thanks Geoff ! OK … when comparing to you, I have the same setup. Thank you for sharing.
I am trying to get to the built in routines. From some other posts, an additional channel … so in your case “LEDs 1: Current value (6)” is generated to help access these built in routines. I am trying to get this 6th channel on my device.
Anyways … I am getting closer as I found this post and was able to manually access the built-in routines by changing the values of the 32-112-0-72 parameter of the zwave web UI config page of MQTT to Zwave … see below:
Next problem is I have no idea of how to make this call via a nice lovelace card … so I can choose “police siren. etc” on a button etc to activate the built-in presets.
Anyone who can point me in a direction … that would be awesome !
All the best
Jason
OK got it working with the preset effects ! … the bloody lovelace editor is awesome !!!
For those interested … I just copied the raw script here … I have no idea what it means, I just used the call service option from the button press …
title: Kitchen Splashback
- badges: []
cards:
- type: custom:light-entity-card
entity: light.pz_kitchen_splashback
effects_list: false
- type: button
tap_action:
action: call-service
service: zwave_js.set_config_parameter
service_data:
parameter: '72'
value: '9'
device_id: 9122beb0bc031a0f37e1b75029154f6f
entity: script.splashback_aurora
icon: mdi:weather-night
icon_height: 25px
- type: button
tap_action:
service_data:
parameter: '72'
value: '6'
entity: script.splashback_fireplace
icon: mdi:fireplace
icon_height: 25px
hold_action:
action: none
- type: button
tap_action:
service_data:
parameter: '72'
value: '7'
entity: script.splashback_fireplace_storm
icon: mdi:weather-lightning
icon_height: 25px
- type: button
tap_action:
service_data:
parameter: '72'
value: '8'
icon: mdi:looks
icon_height: 25px
entity: script.splashback_fireplace_rainbow
- type: button
tap_action:
service_data:
parameter: '72'
value: '10'
icon: mdi:car-emergency
icon_height: 25px
entity: script.splashback_police
Exactly what I want but where do I paste the code ?
#newbie
Hi Tomas,
it under the lovelace dashboard editor / creator … create a new card and paste the above code in a new lovelace dashboard
Thnx alot!
- sorry for the late reply
I’m using this one happily:
looks like this with my predefined favorite colors, and supports smooth transition…
I’m just not sure, if it will work for you…
Hi @JJ6767
Can you pls explain in some more detail how you built the Lovelace card in your screen shot?
- What card type did you add to the dashboard to start with?
- Do you have to create the scripts that you refer to in the YAML code in you post?
Thanks for you help.
I really want to get those Fibaro RGBW programs to be accessible in my HA dashboards.
G.
Hi Clowgg,
Unfortunately I got rid of the zwave device and no longer have the card.
I think I had to create a manual card in the lovelace editor and copy paste the code above in yaml text.
The device ID can be replaced with your fibaro device and can be got from the properties section of the device.
Sorry, but I really forgot
