Recently I bought a Zemismart roller motor of this type: https://www.aliexpress.com/item/Automatic-Electric-Roller-Curtain-Motor-for-38mm-36mm-37mm-tube-Blinds-Shutters-Control-by-Switch-Suit/32854157791.html?spm=a2g0s.9042311.0.0.3e154c4dATN4zx
From my previous apartment, I still had a roller shutter v2 lying around gathering dust, so I gathered that I could reuse that with this motor.
I hooked everything up, pressed the “add node” button in home assistant --> zwave, an then pressed the b button on the roller shutter for 14 seconds, which should, according to the manual reset the device and put it into inclusion mode.
This worked, and I get 2 devices in home assistant:
- cover.fibaro_system_fgrm222_roller_shutter_controller_2_level
- cover.fibaro_system_fgrm222_roller_shutter_controller_2_switch
The first one shows controls for up, down and stop and a slider to set the position.
I tried the controls, and noticed that the motor will only turn counterclockwise when I press the down button or move the slider, I can’t press the up button.
I tried to to a calibration by executing command 29:Forced roller shutter calibration, but that just made the motor spin counterclockwise endlessly while the green led was blinking in the roller shutter.
Since I had the forest atlantis motor that I originally used with the roller shutter still lying around, I connected that one instead of the zemismart motor, but unfortunately, the result was the same.
Any idea what could be the cause of this problem?
I connected the roller shutter motor wires to 01 and 02 on the module, and connected the null line to it, while also connecting N and L to the module.
I also tried to invert the motor wires, which should normally invert the direction of the motor, but when I do that, the module only makes some clicking sound and the motor does not move at all.
