Thats a good idea, use the power report to check only when necessary. I’ll try that! Thanks!!
Does anyone know a roller shutter with which I have up/down and slat position in the same entity? At the moment I’m testing the FGR223.
Subscribing, because I have no idea what would be the best way to control blinds (Shelly vs Fibaro).
Hey there,
I use 13 Fibaro Roller Shutter (FGR-222) since 2016 to control my vetetian blinds with my old smart home controller.
Today I switched them to HA and then realized, that it is quite difficult to control the tilt option…
After some tests I managed to find a solution for my problem.
These are my configuration steps:
- Change report type to “Fibaro Command”
- Mode: Venetian blind
- (Turning time, if necessary)
- Start calibration
In automation I use the following (example: group of blinds, position closed, 20 % tilt → my position is twisted)
alias: Jalousien - Süd 100/20
description: ''
- platform: mqtt
topic: FT55/EZ/Jalousien
payload: '01'
- platform: mqtt
topic: FT55/WZ/Jalousien
payload: '01'
condition: []
- service: cover.set_cover_position
position: 0
entity_id:
- cover.wohnzimmer_ost
- cover.wohnzimmer_sud_links
- cover.wohnzimmer_sud_rechts
- cover.diele_sud_rechts
- cover.esszimmer_sud
- service: zwave_js.set_value
command_class: '145'
endpoint: '0'
property: fibaro
value: 80
property_key: venetianBlindsTilt
entity_id:
mode: single
Hi everyone!
I’m new to the forum and brand new to HA.
9 GRIESSER branded chain blinds will be installed for me next week. I have to choose how to control them and I would like to do it via home assistant. reading around it would seem there are still proglems in managing the position and opening angle of the slats. I err? could you help me choose the most suitable product? fibaro, shelly, qbino, etc? i would like to avoid switching to knx bus. thank you!
Danyrr
Fibaro is working perfectly (in as much as z-wave can work perfectly). I would have preferred Shelly, but they don’t support venetian blinds.
@medicus07 This is exactly what I was looking for. Allow me to ask some questions:
-where do you find the topic: “FT55/EZ/Jalousien”
-what is value: 80?
thnx
I have a Qubino rollershutter but can’t get it to work. Can you say how your way was?
You’ll have to be more specific - what are you trying to do and what happens when you try?
