I have a Fibaro Roller Shutter 3 module installed to control a roller shutter.
It works well, I can control the shutter from Hass.
The device has several entities.
However, (except for the first two), not all other entities change even if the component is in motion.
I managed to «pair it» with Zwave (but deprecated) and I could see different parameters with possible configuration values. (list in doc here: Documentation)
With ZwaveJS, I no longer have that option.
So I can’t get from Hass if the shutter is open or closed, what is its exact position, etc.
How do I get this information?
Also, is there documentation to know what each of the entities corresponds to?
Ty.
Fibaro module’s entities list :
- cover.roller_shutter_3_current_value => Displays the up, down and stop arrow.
- sensor.roller_shutter_3_electric_consumed_w => Works when the flap is in operation
- sensor.roller_shutter_3_electric_consumed_kwh => Works when the flap is in operation
- binary_sensor.roller_shutter_3_power_management_over_current_detected => Remains inactive all the time
- sensor.roller_shutter_3_power_management_over_current_status => Remains unknown all the time
- sensor.roller_shutter_3_system_hardware_status => Remains unknown all the time
- binary_sensor.roller_shutter_3_system_system_hardware_failure_with_failure_code => Remains inactive all the time
- sensor.roller_shutter_3_alarmlevel => Remains unknown all the time
- sensor.roller_shutter_3_alarmtype => Remains unknown all the time
Configuration :
- Raspberry Pi 4B 4Go
- SSD 120Go connected on USB3.0
- Home Assistant OS 2021.2.3
- Clé Zwave Aeotec Z-stick Gen5+
