I bought the Fibaro roller shutter 3 and managed to configure it properly after reading this:
The problem now is with the stop_cover command.
Every time I send this command to the Fibaro roller shutter 3 it does stop but my entire z-wave network freezes. All the calls I make to no matter which z-wave device are delyed.
I looked at the logs and I see the following:
The call to stop_cover is initiated:
2020-10-03 02:46:18.109 Info, Node004, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Bright - 1 - 1 - false
2020-10-03 02:46:18.109 Info, Node004, SwitchMultilevel::StopLevelChange - Stopping the level change
2020-10-03 02:46:18.109 Detail, Node004, Queuing (Send) SwitchMultilevelCmd_StopLevelChange (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x26, 0x05, 0x25, 0x2b, 0xce
2020-10-03 02:46:18.109 Detail, Node004, Queuing (Send) SwitchBinaryCmd_Get (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x25, 0x02, 0x25, 0x2c, 0xcd
2020-10-03 02:46:18.109 Detail, Node004, Queuing (Send) SwitchMultilevelCmd_Get (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x26, 0x02, 0x25, 0x2d, 0xcf
2020-10-03 02:46:18.110 Detail, Node004, Queuing (Send) MultiChannel Encapsulated (instance=2): SwitchMultilevelCmd_Get (Node=4): 0x01, 0x0d, 0x00, 0x13, 0x04, 0x06, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x02, 0x25, 0x2e, 0xa1
2020-10-03 02:46:18.110 Detail, Node004, Queuing (Send) MultiChannel Encapsulated (instance=3): SwitchMultilevelCmd_Get (Node=4): 0x01, 0x0d, 0x00, 0x13, 0x04, 0x06, 0x60, 0x0d, 0x01, 0x02, 0x26, 0x02, 0x25, 0x2f, 0xa3
2020-10-03 02:46:18.110 Detail, Node004, Queuing (Send) MeterCmd_Get (Node=4): 0x01, 0x0a, 0x00, 0x13, 0x04, 0x03, 0x32, 0x01, 0x00, 0x25, 0x30, 0xc7
2020-10-03 02:46:18.110 Detail, Node004, Queuing (Send) MeterCmd_Get (Node=4): 0x01, 0x0a, 0x00, 0x13, 0x04, 0x03, 0x32, 0x01, 0x10, 0x25, 0x31, 0xd6
2020-10-03 02:46:18.110 Detail, Node004, Queuing (Send) MultiChannel Encapsulated (instance=2): MeterCmd_Get (Node=4): 0x01, 0x0e, 0x00, 0x13, 0x04, 0x07, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x01, 0x00, 0x25, 0x32, 0xa8
2020-10-03 02:46:18.110 Detail, Node004, Queuing (Send) MultiChannel Encapsulated (instance=2): MeterCmd_Get (Node=4): 0x01, 0x0e, 0x00, 0x13, 0x04, 0x07, 0x60, 0x0d, 0x01, 0x01, 0x32, 0x01, 0x10, 0x25, 0x33, 0xb9
2020-10-03 02:46:18.110 Info, Node004, CentralScene RequestState: 4
2020-10-03 02:46:18.111 Info, Node004, CentralScene: Not a StaticRequest
2020-10-03 02:46:18.111 Detail, Node004, Queuing (Send) AlarmCmd_Get (Node=4): 0x01, 0x0c, 0x00, 0x13, 0x04, 0x05, 0x71, 0x04, 0x00, 0x08, 0x01, 0x25, 0x34, 0x8c
2020-10-03 02:46:18.111 Detail, Node004, Queuing (Send) AlarmCmd_Get (Node=4): 0x01, 0x0c, 0x00, 0x13, 0x04, 0x05, 0x71, 0x04, 0x00, 0x09, 0x01, 0x25, 0x35, 0x8c
2020-10-03 02:46:18.111 Detail, Node004, Queuing (Send) MultiChannel Encapsulated (instance=2): AlarmCmd_Get (Node=4): 0x01, 0x10, 0x00, 0x13, 0x04, 0x09, 0x60, 0x0d, 0x01, 0x01, 0x71, 0x04, 0x00, 0x08, 0x01, 0x25, 0x36, 0xf3
2020-10-03 02:46:18.111 Detail, Node004, Queuing (Send) MultiChannel Encapsulated (instance=2): AlarmCmd_Get (Node=4): 0x01, 0x10, 0x00, 0x13, 0x04, 0x09, 0x60, 0x0d, 0x01, 0x01, 0x71, 0x04, 0x00, 0x09, 0x01, 0x25, 0x37, 0xf3
2020-10-03 02:46:18.111 Info, Node004, Sending (Send) message (Callback ID=0x2b, Expected Reply=0x13) - SwitchMultilevelCmd_StopLevelChange (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x26, 0x05, 0x25, 0x2b, 0xce
2020-10-03 02:46:18.119 Detail, Node004, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-10-03 02:46:18.120 Detail, Node004, ZW_SEND_DATA delivered to Z-Wave stack
2020-10-03 02:46:18.136 Detail, Node004, Received: 0x01, 0x07, 0x00, 0x13, 0x2b, 0x00, 0x00, 0x03, 0xc3
2020-10-03 02:46:18.136 Detail, Node004, ZW_SEND_DATA Request with callback ID 0x2b received (expected 0x2b)
2020-10-03 02:46:18.136 Info, Node004, Request RTT 24 Average Request RTT 24
2020-10-03 02:46:18.136 Detail, Expected callbackId was received
2020-10-03 02:46:18.136 Detail, Expected reply was received
2020-10-03 02:46:18.136 Detail, Message transaction complete
2020-10-03 02:46:18.136 Detail, Node004, Removing current message
2020-10-03 02:46:18.136 Info, Node004, Sending (Send) message (Callback ID=0x2c, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x25, 0x02, 0x25, 0x2c, 0xcd
2020-10-03 02:46:18.145 Detail, Node004, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-10-03 02:46:18.145 Detail, Node004, ZW_SEND_DATA delivered to Z-Wave stack
2020-10-03 02:46:18.160 Detail, Node004, Received: 0x01, 0x07, 0x00, 0x13, 0x2c, 0x00, 0x00, 0x02, 0xc5
2020-10-03 02:46:18.160 Detail, Node004, ZW_SEND_DATA Request with callback ID 0x2c received (expected 0x2c)
2020-10-03 02:46:18.160 Info, Node004, Request RTT 23 Average Request RTT 23
2020-10-03 02:46:18.160 Detail, Expected callbackId was received
and then after ~10 sec I get the following:
2020-10-03 02:46:28.137 Error, Node004, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-10-03 02:46:28.137 Detail, Node004, Removing current message
2020-10-03 02:46:28.137 Detail, Node004, Notification: Notification - TimeOut
2020-10-03 02:46:28.142 Detail,
2020-10-03 02:46:28.142 Info, Node004, Sending (Send) message (Callback ID=0x2d, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x26, 0x02, 0x25, 0x2d, 0xcf
2020-10-03 02:46:28.150 Detail, Node004, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-10-03 02:46:28.150 Detail, Node004, ZW_SEND_DATA delivered to Z-Wave stack
2020-10-03 02:46:28.167 Detail, Node004, Received: 0x01, 0x07, 0x00, 0x13, 0x2d, 0x00, 0x00, 0x02, 0xc4
2020-10-03 02:46:28.167 Detail, Node004, ZW_SEND_DATA Request with callback ID 0x2d received (expected 0x2d)
2020-10-03 02:46:28.167 Info, Node004, Request RTT 24 Average Request RTT 23
2020-10-03 02:46:28.167 Detail, Expected callbackId was received
2020-10-03 02:46:28.211 Detail, Node004, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x04, 0x05, 0x26, 0x03, 0x22, 0x22, 0xfe, 0x2a
Any ideas why this is happening and how to fix it?
Thanks,
Max
